RV.Net Open Roads Forum: Truck Campers: Hardside that fits thru 8'x8' opening
 > Hardside that fits thru 8'x8' opening
GeoBoy
Bennington
Posted: 04/07/20 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Northstar TC’s make 3 models that are 84” wide and 8’ tall with a roof top AC.
mkirsch
Rochester, NY
Posted: 04/09/20 07:26am Link  |  Quote  |  Print  |  Notify Moderator
bluegmc wrote:
Thanks everyone for the advice, I will send some emails to Mfgers of the ones I am interested in and if that does not work look for storage options.
The manufacturers will simply parrot the specs off their brochures/websites. They will not tell you the actual story. You will need to go to the dealerships and measure for yourself.
kohldad
Goose Creek, SC
Posted: 04/10/20 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
Lance 815 would fit. It's 7" narrower than most. On my truck I'm 10'-6" but the bed is 32" which means total height including AC would be 7'-10". You could easily gain about 5" more clearance by going with a low profile AC unit.
Any unit with a basement isn't going to fit so you can rule them out quickly. Unfortunately, that is most of the newer units.
The bad is it has small tanks, even smaller wet bath and only 6-2 inside. But I've been using mine for 11 years now and it's still in great shape.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
