RV.Net Open Roads Forum: Tech Issues: Crack in ball valve
 > Crack in ball valve
Cummins12V98
on the road
Posted: 04/10/20 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor wrote:
The 310 ball cracking goes back more than 5 years, I learned this the hard way long ago with a crack just like the original photo. Toilet is just throw away junk.
I had never heard of it til it happened to me. I have been on several Forums for many years.
Mine is 5 years old. I wonder if it’s something that has been updated.
I was very pleased my repair worked so well.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
VinnyP
Bronx,NY
Posted: 05/24/20 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
took the coward's way out. Replaced the whole toilet. Literally took 15 minutes. Thanks for all the input
Vinny & Rita
The Bronx, NY
2013 F350 Lariat 6.7L PSD CC
2012 Cedar Creek 36B4
2009 Holiday Rambler Savoy LX
2015 Rockwood 2109S Mini-Lite
DFord
Near St Louis, MO
Posted: 05/24/20 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Did you try something else or did you go back with the same 310?
Edd505
Elephant Butte, NM
Posted: 05/24/20 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
I did mine on the road last year, Aqua Magic died leaking on the floor. New 310 $150-200 why mess with it? BTW I would never go back to the Aqua Magic the 310 actually flushes.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Cummins12V98
on the road
Posted: 05/24/20 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
I am NOT a tight wad. BUT I sure don't like to replace anything if I can fix it.
My Superglue fix worked until a couple weeks ago. I am now at my home base and thought about removing the toilet but instead I turned off the water to toilet and reached in and cleaned off the bottom of the "BALL". I then put s few ounces of LocTite PL3 in my gloved hand and placed an even layer on the bottom of the ball. I let it dry for a couple days but when I really let it slam the cured pc separated and was inside the tunnel so I reached down and removed it.
Not giving up yet!!! I cleaned the bottom again then scrubbed it with emory cloth then cleaned with Acetone. I mixed up JB weld and smeared a thick layer on bottom of ball. Let it set overnight. I have been using it and snapping ball into place for over a week now!!!
NEVER GIVE UP!!!
