RV.Net Open Roads Forum: Travel Trailers: Bent frame
 > Bent frame
scotty46
Indiana
Posted: 04/12/20 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Back of travel trailer was hit by a falling tree during storm. Bent back 4-5 feet of trailer on one side. The "box" is fine, just frame. Repair shop said they could cut out bad part and weld in a replacement. Is this something someone else has experienced. Does it work in the long run. I am a little cautious that this really works. Opinions?
IDman
Oklahoma
Posted: 04/12/20 07:56am Link  |  Quote  |  Print  |  Notify Moderator
Curious as to how a falling tree could damage the frame (which is on the bottom) and not damage the more fragile "box" of the trailer. Could you please show photos or explain?
Williams AZ area
Posted: 04/12/20 08:26am Link  |  Quote  |  Print  |  Notify Moderator
I’d trust a frame shop to fix it.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
shum02
Burlington ON CDA
Posted: 04/12/20 08:44am Link  |  Quote  |  Print  |  Notify Moderator
I think my insurance company would write that off.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
bid_time
Michigan
Posted: 04/12/20 08:51am Link  |  Quote  |  Print  |  Notify Moderator
My opinion would depend on what the experience and skill of the shop is. Some I would trust, some I wouldn't let them check the air in a flat tire.
wanderingbob
monticeeo, fla
Posted: 04/12/20 10:32am Link  |  Quote  |  Print  |  Notify Moderator
A good welder can fix anything except a broken heart ,
Ivylog
Blairsville, GA and WPB, FL.
Posted: 04/12/20 11:22am Link  |  Quote  |  Print  |  Notify Moderator
As flimsy as the frames are it wouldn’t take much to put it back stronger.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
scotty46
Indiana
Posted: 04/12/20 11:37am Link  |  Quote  |  Print  |  Notify Moderator
As IDman asked, when the tree fell it caught the spare tire, which caused the bumper to bend, which then caused the frame to bend. It also demolished two bicycles. I am not good at posting pictures, but the impact caused the frame to drop about 6 inches back to nothing at 4-5 feet from the bumper. Can see wiring, pipes and the "black" tank in the gap, so I am concerned about the integrity of the water system and electrical. Also concerned about the long term endurance of the body and frame as the damage is at the end of the trailer where there would be more bounce as you travel down the road. For the sake of 6 inches, it did no damage to the "box" but in sure did bend the frame. Lost five trees in the storm that included up to 80 mph straight line winds. The trees were pines that had been planted in the 30's by the CCC. Pines are pretty weak.
JIMNLIN
Oklahoma
Posted: 04/12/20 11:49am Link  |  Quote  |  Print  |  Notify Moderator
WOW...if the frame is bent down 6" then you will have trailer structure damage like in the sidewalls and back wall pulled loose from the floor or floor pulled loose from the frame. If it didn't then look close at the roof and top of the sidewalls above the bent area.
I would have someone with this type of experience check it all out for you.
A experienced big rig trailer repair shop can repair the main frame rails/cross members....stronger than OEM.
What does your insurance company saying ??
dodge guy
Bartlett IL
Posted: 04/12/20 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
If that's all that got damaged then yes the frame rails can be repaired. I'm sure a shop can do better than what the manuf boogered together. Just inspect the box where it attaches to the frame and make sure none of the wood (or aluminum if that how it's framed) was damaged!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
 > Bent frame
