RV.Net Open Roads Forum: General RVing Issues: Anode's Rapid Demise
 > Anode's Rapid Demise
Cummins12V98
on the road
Posted: 04/12/20 12:38pm Link  |  Print  |  Notify Moderator
Fellow DRV owner has RAPID Anode deterioration, pic below is after just 9 months.
He uses a standard blue Camco inline filter then "On the Go double Water Softener" then whole house filter.
This seems CRAZY to me. I know my water at home base in WA is good along with our Winter location in SoCal. Our Anode 2nd pictured is at least 3 years old.
Any ideas????????
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
larry barnhart
wenatchee. wa usa
Posted: 04/12/20 12:45pm Link  |  Print  |  Notify Moderator
Way too much telfon tape and this will not let the rod do it's thing. Your tank will die early. Just one wrap is best. The male threads need to touch the female threads. chevman I now use pipe compound.
chevman
chevman
2021 Jayco Hawk 28RL
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
dodge guy
Bartlett IL
Posted: 04/12/20 12:48pm Link  |  Print  |  Notify Moderator
On my trailer one season will take out a rod and then the next one will last 3 seasons. Not sure why. Could be the maker of the rod. I just inspect it at the beginning of the year and decide if I need new or reuse.
* This post was edited 04/12/20 12:54pm by dodge guy *
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Lynnmor
Red Lion
Posted: 04/12/20 12:53pm Link  |  Print  |  Notify Moderator
It all depends on the water being used, nothing else. A filter will do nothing to preserve an anode rod.
BB_TX
McKinney, Texas
Posted: 04/12/20 01:06pm Link  |  Print  |  Notify Moderator
Teflon tape is so thin and weak the anode rod threads will immediately cut thru it and make metal to metal contact. Tape is for sealing between threads, not insulating them. Two or three turns of tape is plenty. But use pipe dope if that makes you feel better.
What will have far more impact is whether you use a magnesium rod or an aluminum rod. A magnesium rod will give itself up much faster than an aluminum rod. I replaced an old magnesium rod with aluminum rod one time. That rod still looked almost new 3 years later using same water sources indicating it was not doing much to protect the tank. Now use nothing but OEM magnesium and replace yearly.
Cummins12V98
on the road
Posted: 04/12/20 01:10pm Link  |  Print  |  Notify Moderator
chevman
I mentioned that to him saying I use Permatex Teflon in a squeeze tube.
Cummins12V98
on the road
Posted: 04/12/20 01:14pm Link  |  Print  |  Notify Moderator
Mine pictured basically with a "rash" is Magnesium. Edit: It's actually Aluminum.
"A filter will do nothing to preserve an anode rod."
This makes no sense to me. Guess I don't understand? My water is good, Anode looks good. His water has been made to be good, Anode is bad.
* This post was edited 04/12/20 03:59pm by Cummins12V98 *
Old-Biscuit
Verde Valley
Posted: 04/12/20 01:53pm Link  |  Print  |  Notify Moderator
Do you use a 'water softener'?
Your friend does...correct?
Is his anode rod aluminum?
Aluminum and water softeners are not good combo
9 mos & using a water softener is about average consumption of an anode rod.
Magnesium rod......have a 'tit' on head
Aluminum rod.......smooth head
Teflon tape.....no effect on the cathodic action
Threads on anode rod and drain hole cut thru that tape and make metal to metal contact.
Magnesium has better galvanic current flow then Aluminum.
wildtoad
Blythewood, SC
Posted: 04/12/20 02:06pm Link  |  Print  |  Notify Moderator
The picture of the completely used up anode shows that Teflon tape is fine to use. I wouldn’t waste too much time on this just buy a new one every year and be done with it.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Cummins12V98
on the road
Posted: 04/12/20 02:16pm Link  |  Print  |  Notify Moderator
I do NOT use a water softener. I only use a Pentex Charcoal filter.
He said he used Magnesium, he sent a link and the head has a TIT.
I just looked and based on what you said mine must be Aluminum. Looked at purchase Summer 2016 and it is aluminum.
Just seems like a lot of consumption in 9 months.
Had my well pump and galvanized pipe replaced in NW WA, the Well guy said I had great water and everything was VERY clean.
