RV.Net Open Roads Forum: Fifth-Wheels: Lifting fifth wheel
 > Lifting fifth wheel
joebedford
Sheltering at home
Posted: 04/13/20 07:22am Link  |  Quote  |  Print  |  Notify Moderator
rhagfo wrote:
Sometimes you just get lucky changing TV's! I didn't make any changes to our new 2016 Ram 3500 and still level.
Do you get a lot of people flashing their lights at you if you tow at night?
rhagfo
Portland, OR
Posted: 04/14/20 12:08am Link  |  Quote  |  Print  |  Notify Moderator
I prefer to not tow at night,so no I don't. Both TV sit level or better.
justme
Posted: 04/21/20 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know about RAM but Ford offers rear blocks to lower the rear in one-inch increments. I suspect RAM and GM offer the same. The 2017+ F350 SRW 4wheel drive is approx. 3 inches high to look more macho. Therefore it can be lowered the same amount with the appropriate mod. Aftermarket folks also offer lowering blocks for the rear as well. Search the Inet and you will find a lot of options.
http://www.pmfsuspension.com/2017-20-Ford-Superduty-Fabricated-Blocks_p_173.html
* This post was edited 04/25/20 09:15am by justme *
Cummins12V98
on the road
Posted: 04/21/20 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
My 15 RAM DRW rides with a positive 1" rake on the rear unloaded or running at full RAWR with the Factory Rear Air Ride in the Alt Ride position.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
RJ Driver
Utah
Posted: 05/02/20 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
We lifted our 5th wheel 4 inches two years ago when we bought it. I had a fabricator weld a 4 inch subframe with support bracing and exact matching spring hangers. Unbolted the springs from the hangers, lifted the trailer up and bolted the subframe in the stock hangers. Then bolted the springs into the new hangers under the subframe. It has worked perfectly! If I ever sell the trailer and someone doesn’t need the lift it can be unbolted, removed and put back to stock height.
2011 F-350 6.7 Powerstroke
2017 Keystone Cougar 326RDS
Anderson Ultimate
ifd22
Northern Kentucky
Posted: 05/03/20 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
I ended up up having it lifted by a local spring shop. They added 4” by 2” steel below the frame, added cross bracing and welded the spring hangers to the new steel. Did a very neat and clean job. I’m still 2” nose high, but I can now get in the driveway.
2019 Primetime lite Crusader
2018 Ram 2500 Crewcab CTD
Andersen hitch
Likes to tow
Huntington WV
Posted: 05/04/20 04:14am Link  |  Quote  |  Print  |  Notify Moderator
I cannot understand why truck manufacturers make trucks too tall. It seems wrong for me to raise the center of gravity of my trailer just to accommodate the taller bed on new trucks. I've now decided to just keep my 05 Ram 2500!!
ford truck guy
Pennsylvania
Posted: 05/04/20 06:18am Link  |  Quote  |  Print  |  Notify Moderator
A lot of folks were complaining about just that and Ford listened.. My "20" sits 2" lower that my recent "15" sat...
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
lee worsdell
elmvale
Posted: 05/04/20 06:43am Link  |  Quote  |  Print  |  Notify Moderator
That hitch looks way back to was that for a reason or is it just the pic
BarneyS
S.E. Lower Michigan
Posted: 05/04/20 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Lee, it looks to me like the pin is directly above the axle. He has an extended pin pox I think.
Barney
Not towing now.
