RV.Net Open Roads Forum: Truck Campers: TPM
specta
utah
Posted: 04/14/20 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
double post
Kenny
2011 Chevy 2500 HD 6.0L 4wd
6580 lb truck 10540 fully loaded
kohldad
Goose Creek, SC
Posted: 04/14/20 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
When I was towing a 12k FW with my diesel, I've seen it go from 80psi @ 70* in the morning to almost 110psi after 300 miles and temps rising to 95*.
Just remember, don't let air out just because it goes over max pressure after driving. Tires are to be checked when cold which means less than 1 mile of driving and no sun shining on them. The tire manufacturers design in the rise of pressure.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
Oregun
Oregon
Posted: 04/15/20 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Didn't realize until I looked that they have TPMS devices now that just screw on the tire valves.
Was thinking they only went inside the tires.
PSD w/ Lance 845
encinitas
Posted: 04/22/20 10:37am Link  |  Quote  |  Print  |  Notify Moderator
deserteagle56 wrote:
billtex wrote:
I can tell you; having TPM-especially in a SRW -is a game changer.
Couldn't agree more.
I'm considering a TPM for my rig and Jeep trailer. My concern is that you're adding another failure/air leakage point to the system.
Which aftermarket brands/model numbers do you guys use?
Kayteg1
California > Nevada
Posted: 04/22/20 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
I still have add-on TPMS I bought like 15 years ago for my motorhome at the time.
If you have metal tire stems - it works very well. In case you have leek, you will get warned.
Leaving the monitor on overnight will give you theft warning as well.
Since then the market was flooded (I paid small fortune to only manufacturer 15 years ago) so I would go with what local guys recommend.
Getting it local solves potential warranty claims faster.
Oregun
Oregon
Posted: 04/22/20 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Haven't bought one yet but was looking at this one which goes up to 116psi. Wish they had an extra readout for the spare too.
Rustofer
Vancouver Island
Posted: 04/22/20 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Mine are set at 80 cold; usually they run in the low 90's, and I've had them hit 99 on the highway in the summer. I wondered if the TPMS was maxed out at that point. F350 SRW, loaded to roughly 7200 lbs on rear axle.
billtex
RI
Posted: 04/22/20 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
I use a cheapie off AMZ Link it works great!
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
billtex
RI
Posted: 04/22/20 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
specta
utah
Posted: 04/22/20 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
I had the factory TPM disabled on my truck.
The light would come on a 65 psi.
Empty I run 50 psi in the front and 45 psi in the rear.
The tires wear even running those pressures.
