RV.Net Open Roads Forum: Truck Campers: TPM
specta
utah
Posted: 04/14/20 08:24am Link  |  Quote  |  Print  |  Notify Moderator
How high does your tire pressure get in the summer traveling down the HWY with your camper fully loaded??
Kenny
2011 Chevy 2500 HD 6.0L 4wd
srschang
Western NY
Posted: 04/14/20 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Rear tires are 80 psi cold, I've seen it as high as 92 psi summer highway.
2020 Ram 3500 SRW Crewcab Longbed Cummins, 2019 Northstar 12 STC
Posted: 04/14/20 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Never checked um, but it's a function of barometric pressure (altitude) and tire temp.
About 1/2 psi per 1000' altitude gain or loss and 1+ psi per 10 degrees up or down.
Set it and forget it, unless you have wild temperature or altitude changes.
Easy to get a 10+ psi swing in pressure.
Why do you ask?
2017 Heartland Torque T29
RCMAN46
NorthWest
Posted: 04/14/20 09:41am Link  |  Quote  |  Print  |  Notify Moderator
Rear tires are 80 psi cold, I've seen it as high as 95 psi summer ambient 95 F highway towing a 5th wheel trailer.
2005 2500 Chevrolet.
specta
utah
Posted: 04/14/20 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies.
A friend of mine says he has seen his TT tire as high as 100 psi.
billtex
RI
Posted: 04/14/20 10:39am Link  |  Quote  |  Print  |  Notify Moderator
I run the rears at 80 psi and have also seen them climb into the 90 psi range. I added an aftermarket TPM to my Chevy after having a blowout and then getting all new (heavier) tires. This kind of freaked me out as i did not expect to see the psi so high. I believe I posted the same question here about 1 year ago and upper 90’s was the consensus-so I felt better.
I can tell you; having TPM-especially in a SRW -is a game changer.
The new truck will have an OE system.
Stay safe, Bill
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
Kayteg1
California > Nevada
Posted: 04/14/20 11:12am Link  |  Quote  |  Print  |  Notify Moderator
If you have higher-end scanner, some cars also have temp sensors build into TPMS.
When they will not show on cluster, the scanner might show them.
Worth checking as most of tire blow due high temperature.
deserteagle56
Nevada
Posted: 04/14/20 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Stay safe, Bill
Couldn't agree more.
I drive a lot of rocky dirt roads and it is wonderful to get that alarm and be able to pull over and stop before the tire is destroyed. For my 2007 rig that doesn't have OEM TPMS I bought an aftermarket setup that constantly displays the pressure AND temperature of each tire. Wish I'd had something like this years ago - would have saved me a lot of money for replacement tires.
1996 Bigfoot 2500 9.5 on a 2004 Dodge/Cummins dually
specta
utah
Posted: 04/14/20 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Why do you ask?
Just curiosity.
I'm not having any issues.
specta
utah
Posted: 04/14/20 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
triple post LOL
