RV.Net Open Roads Forum: Towing: Class V Hitch?
Search only in Towing
Open Roads Forum  >  Towing
 > Class V Hitch?
Melon Seed
San Jose
Posted: 04/14/20 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
I have a brand new F350 with a class V hitch. It's 2.5" square. I'm getting a sleeve to insert so I can use my existing weight distribution hitch, 2". Thoughts on "needing" the torsion bars for weight distribution....
DarkSkySeeker
Freestone, California
Posted: 04/14/20 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
I did not know the receivers came in larger sizes than 2".
I could see perhaps not using the bars for weight distribution. But I'd always want them for anti-sway.
There is something special about camping in an RV.
Near Mammoth, CA
Posted: 04/14/20 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Dark, yes, that’s the newish thing...2 1/2 inches.
Posted: 04/15/20 12:47am Link  |  Quote  |  Print  |  Notify Moderator
Melon seed, do not use an adapter sleeve except for light duty or infrequent towing. It'll bend the hitch pin and wallet out the pin holes in the receiver.
Couldn't even guess whether you need your wd bars. A lot of RVers use them as a crutch or pacifier. Some need them.
shum02
Burlington ON CDA
Posted: 04/15/20 04:57am Link  |  Quote  |  Print  |  Notify Moderator
All Super Duty's since I don't know when have had Class V 2.5" receivers. My '06 does as well.
How much tongue weight do you have now? All loaded out my rig is about 8000lbs including about 900lbs+ of tongue weight and I do use the WD bars but have them set on the lowest setting that is recommended. The Super Duty's hate to much weight being transferred to the front end as they just don't need it and it will affect the handling of the truck.
The rear axle of these trucks will take a LOT of weight, give it to them.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
AH64ID
Kuna, Idaho
Posted: 04/15/20 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Technically you will not need them; however, you will prefer to use them.
Sway aside, as that's another topic, the weight distribution bars will improve the handling of your TV and reduce porpoising while driving on uneven roads.
I don't need the WDH to tow my TT, and often don't use it around town, but it's a noticeable difference.
I also recommend either getting a 2.5" shank or welding the sleeve to the existing shank. It will reduce slop, wear, and noise.
-John
2018 Ram 3500-SRW-4x4-Laramie-CCLB-Aisin-Auto Level-5th Wheel Prep-Titan 55 gal tank-B&W RVK3600
2011 Outdoors RV Wind River 275SBS-some minor mods
camperfamily
New Jersey
Posted: 04/15/20 07:39am Link  |  Quote  |  Print  |  Notify Moderator
I second the recommendation to get a 2.5" shank. Much tighter, quieter connection. Try E-trailer or your favorite retailer.
2011 Cougar 322QBS
2007 Pilgrim 278BHSS (Sold)
2013 F350 CC LB 6.7
2002 F350 CC LB PS (Retired)
B&W Companion Hitch
rwess
Georgia
Posted: 04/15/20 07:47am Link  |  Quote  |  Print  |  Notify Moderator
2500/250 trucks have always had 2.5 inch shank receivers, I think. My 2010 2500HD Chevy does. I changed out the 2 inch shank on my Equalizer hitch to a 2.5 inch shank. I figured it would give me an added degree of safety and hopefully less wobble. It is really heavy now, and I did not notice much of an improvement in wobble. I later added an heavy duty anti wobble clamp device to completely eliminate wobble.
rwess
USN Ret.
2017 Open Range 216RBS
2010 Chevy 2500HD Z71 4x4 LT
Lynnmor
Red Lion
Posted: 04/15/20 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Time for you guys to get caught up, 3" receivers have been out for a few years now.
If you have a 2-1/2" receiver, get the proper shank, use the 2" adapter for small utility trailers.
Melon Seed
San Jose
Posted: 04/15/20 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all for your thoughts and info.
 > Class V Hitch?
