M.R.E.
MI, usa
When I am on my way home, if I stay at a place without electricity, will my inverter run down my batteries too low ?
toolmaker
jdc1
Rescue, Ca
Yep. You'll need to run your generator or have a lot of solar output.
CA Traveler
The Western States
It depends upon how much power the inverter uses, battery charge and capacity.
For every 120V amp for inverter output it will draw 11 times that many amps from the battery.
2014 Grand Cherokee Overland
Bob
Lake Crowley area, California
Adequate batteries and solar charging would make you independent of an electric hookup. Run the numbers...battery amp hours, fridge and other draws...see what you are using.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
2oldman
NM
More information, please.
Sandia Man
Rio Rancho, NM
Since there are several variables involved in determining how long an inverter can power an AC load, without pertinent info it's likely you will need to replenish your battery bank if staying more than a day, sooner if you only have a couple of batteries. We do most of our RVing off the power grid utilizing solar and occasionally our genny/Iota IQ4 smart converter to quickly restore consumed amphours to our 12 volt reserves.
theoldwizard1
SE MI
M.R.E. wrote: When I am on my way home, if I stay at a place without electricity, will my inverter run down my batteries too low ?
All inverters will shutdown if the voltage get too low. The question is "What is too low ?" and "Will that damage your batteries ?"
Not enough information ! Make and model of inverter. Make, model, quantity of batteries.
Cummins12V98
on the road
I drove 36 hours stopping to take 2 hour naps the frig 38 freezer 0 when arrived. I left the truck running the whole time.
So to answer your question who knows!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
time2roll
M.R.E. wrote: When I am on my way home, if I stay at a place without electricity, will my inverter run down my batteries too low ? Maybe, maybe not. Two well charged batteries and pre-cooled fridge should make a 12 hour stop with minimal time with the door open. Bad time to chill a case of warm beer. Otherwise the battery will be a bit low in the morning but will begin charging from the alternator as soon as you roll. Battery may arrive home a bit low as charging will be slow to none as the inverter will use most of the power from the truck. So plug in and charge 5+ hours when you get home. Two nights in a row could be more of a challenge with no generator.
675w Solar pictures back up
Merrykalia
Appalachian (apple at chun) Mtn in the GREAT SW Va
How far is home? We have driven 3 days with overnight stopping in between and our fridge was still cold when we arrived. I guess it will depend on how topped off the batteries when you leave, outdoor temp, how many batteries you have and lots of other variables. I will say that our batteries died on one trip, but the fridge and freezer still held their cold.
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
