RV.Net Open Roads Forum: Class A Motorhomes: Cost to install apparatus for Flat-towing
 > Cost to install apparatus for Flat-towing
Page of 6
johnwalkerpa1
Pennsylvania
Posted: 07/30/20 09:21am Link  |  Quote  |  Print  |  Notify Moderator
obiwancanoli wrote:
I concluded the Readybrake not as effective simply because using the brakes on the toad would seem to me to be more effective. I have no other evidence to support my conclusion, but am happy to accede to more knowledgeable sources...
way2roll wrote:
obiwancanoli wrote:
OK, here's something else I'm researching... braking systems.
Also happened across a Readybrute with built-in braking mechanism, and concluded it's probably not as effective as what's needed, but again, am a rookie at this... which explains why I'm posting this...
Why would you conclude the ready brute elite not as effective? This is likely the most simple, effective and risk risk free set up you can have. It's a surge brake built into the bar itself and uses your own car's braking system. It's all mechanical so no wiring to fail, no air or hydraulics to fail, nothing to install/uninstall every time you hook up.
The readybrute still uses the toad's brakes. It just activates them differently. IMHO it's a better way. It's a little extra setup to run the cable thru the firewall but once you do that once, it's much simpler to use than any other braking system I've ever seen.
B.O. Plenty
Minnesota
Posted: 07/30/20 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Big Katuna wrote:
So if I buy new, use it ten years, it gets worn out and fails, you’ll be ok?
Have you heard of anybody that’s has been sued for equipment failure?
Bald tires? Overweight?
Insurance pays for all that. Civil suits happen but they are rare.
100% correct. The sky is not falling. Pretty easy to look at a tow bar and mount to see if something is wrong with it.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
crawford
Dandridge Tenn.
Posted: 07/30/20 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
tow bars have safety cables or chains ready brake or others have lights telling if hooked up pretty simple. If you run bald tires nothing helps stupid. Use your equipment required all will be well but still can't fix stupid.
Change from a c class to a A class Georgetown 07 triple slide
Tax_Man
Sioux City IA
Posted: 07/31/20 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
I use the Demco (SMI) Stay and Play brake system. It stays in place. Flip and on/off switch when hooking up. Works great.
Traveling around with the wife and fur kid.
Keep on Truckin (It's a 70s thing)
2007 Georgetown SE 350DS (Ford Chassis)
2007 Jeep Liberty Limited 4x4 (Toad)
Page of 6
