RV.Net Open Roads Forum: new coachmen prism 2200fs - what does this switch do?
 > new coachmen prism 2200fs - what does this switch do?
meauslix
Posted: 04/19/20 08:47am Link  |  Quote  |  Print  |  Notify Moderator
hello all,
I purchased my first motorhome this week...a 2020 coachmen prism 2200fs. I've always had bumper pull trailers and couldn't be more thrilled with the change! I took it out camping off the grid this weekend and cannot figure out what one of the switches does, nor can I find it in any of the documentation.
its a blue lit-up switch under the cabinets above the sink. I have attached a photo for reference. any ideas? I'll put a call into the dealership tomorrow. Thanks!
https://imgur.com/a/wBVJc93
lawrosa
Horry County
Posted: 04/19/20 08:56am Link  |  Quote  |  Print  |  Notify Moderator
here is your pic...[image]
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
lawrosa
Horry County
Posted: 04/19/20 08:57am Link  |  Quote  |  Print  |  Notify Moderator
It should be for the outside LED light strip
MDKMDK
Canada
Posted: 04/19/20 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Was gonna guess external llighting of some sort, maybe porch light, but you're probably right about LED awning lights or similar.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
bobndot
Posted: 04/19/20 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
Does your rv have a lighted grab handle or a dump station light ?
You can also check if you have an automatic entrance light that operates with the screen door . Those lights can be off and on. Sometimes its an exterior step light or a light just inside the entrance.
Open the baggage doors to see if you have lights inside that can be disabled with that switch.
* This post was edited 04/19/20 01:16pm by bobndot *
meauslix
Posted: 04/19/20 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all.
So the outside LED light strip under the awning has a labeled switch on the control panel. There isn't a grab handle, or a dump station light that I can see. I have tried so many different combinations, and I cant figure it out. Besides all the interior light switches, it is the only switch that isn't labeled. Hrmmmm.
MDKMDK
Canada
Posted: 04/19/20 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
meauslix wrote:
Thanks all.
Did it come with a tanning bed? [emoticon]
K Charles
Connecticut
Posted: 04/19/20 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
Electric water heater or water pump?
cavie
Posted: 04/19/20 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
Pump switch.
lawrosa
Horry County
Posted: 04/19/20 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
I would maybe say it turns the pop up power port on near the sink. The usb plugs use idle power and its probably a kill switch.
