RV.Net Open Roads Forum: new coachmen prism 2200fs - what does this switch do?
 > new coachmen prism 2200fs - what does this switch do?
lawrosa
Horry County
Posted: 04/19/20 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
I would maybe say it turns the pop up power port on near the sink. The usb plugs use idle power and its probably a kill switch.
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
meauslix
Posted: 04/19/20 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
its not the water pump. that switch is labeled, and on the main panel. There is a pop up power port by the sink. Im going to go check it now. thx.
lawrosa
Horry County
Posted: 04/19/20 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Since its blue it may be to turn on the outdoor bluetooth speaker? Uou have outside entertainment?
meauslix
Posted: 04/19/20 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
it had no affect on the pop up USB power port. Also, I do not have outside entertainment. The only bluetooth is the speaker system inside, and the TV/soundbar. Starting to wonder if tanning bed guy was right, and I just haven't found it yet.
Here is what's on the control panel:
* This post was edited 04/19/20 05:53pm by meauslix *
cavie
Posted: 04/19/20 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
Some RV's have 2 or 3 pump switch's. 1 kit, 1 bathroom. 1 outside shower. Try it at night to see if it is something outside.
lawrosa
Horry County
Posted: 04/19/20 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
baffling.. as every video I watched of the walkthoughs on that model show that switch on.. Do you have an inverter maybe>
meauslix
Posted: 04/19/20 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
yeah, I checked and with the main water pump switch on, every water item worked including the outside shower. there was an optional outside tv/entertainment item that I do not have. I even checked to see if it controlled the outlet inside that hatch...it does not.
im not sure about an inverter.
lawrosa
Horry County
Posted: 04/19/20 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
turns on a light inside the largest side storage compartment maybe?
MDKMDK
Canada
Posted: 04/19/20 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
I forgot to ask. What's the prize for the person who gets the right answer? [emoticon]
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
LadyRVer
Posted: 04/19/20 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
I had a blue led light like that in my new truck camper. It was a night light!
Call the dealer back and ask...
