RV.Net Open Roads Forum: Fifth-Wheels: First Cat Scale Weigh In
 > First Cat Scale Weigh In
allen8106
Burrton. KS
Posted: 04/22/20 10:03am Link  |  Quote  |  Print  |  Notify Moderator
2018 GMC 3500 DRW
9,375 - GAWR - Rear
5,600 - GAWR - Front
13,025 - GVWR
4,619 - Max Cargo
2010 Jayco 31.5 RLDS 5th Wheel
8,900 - Advertised dry weight
2,120 - Advertised dry pin weight
2,500 - Advertised cargo capacity
11,400 - Advertised GVWR
Loaded for road trip.
Truck and Camper
5,040 - Steer Axle
6,820 - Drive Axle
8,302 - Trailer Axles
20,180 - Gross Weight
Truck Alone
5,040 - Steer Axle
4,060 - Drive Axle
2,760 - Pin Weight
11,080 - Camper Weight
-I found it interesting that the steer axle weight was the same with or without the 5ver hooked on.
-320 lbs under 5ver cargo capacity.
-Truck weight includes, driver, dog, generator, 5ver power cable, blue boy tote, tackle box, fishing poles and cooler.
-2,555 lbs under drive axle weight rating
* This post was edited 05/02/20 10:19am by allen8106 *
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 36
JIMNLIN
Oklahoma
Posted: 04/22/20 11:43am Link  |  Quote  |  Print  |  Notify Moderator
I always set my GN and 5th wheel trailer hitch(s) to where it doesn't affect the trucks front axle much if any.
Your 4060 lb drive axle empty weight is one of the highest I've seen even on haulers websites. Is the 4060 lbs number as is from the factory or after you added your stuff in the truck.
neal10a
Madison CT
Posted: 04/22/20 11:44am Link  |  Quote  |  Print  |  Notify Moderator
It's called leverage. The Fifth wheel pin is usually 1 inch ahead of the drive axel for most units. That would not produce much wieght to the front axle. It would be less the 100 lbs. If it was directly on top of the drive axle it would 0 lbs on the front axle.
valhalla360
No paticular place.
Posted: 04/22/20 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, simple beam calculation. Assuming the pin is centered 1 inch ahead of the axle.
2760 pin weight * 1 inch = 2760 in-lb
To counter that assuming 168 in wheel base
2760 in-lb / 168 in = 16.4lb of upward lift on the front axle.
I believe CAT scales round off the results plus there is an allowable error...so not surprising that it came out the same with or without.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Old-Biscuit
Verde Valley
Posted: 04/22/20 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
5vr pin weights are 'carried' by trucks rear axle.....
Depending on location of hitch truck front axle weight can be affected.
2" forward of rear axle center line on my truck ADDS 150# to front axle which was intended due to heavy pin weight.
Your 5vr DRY pin is 24% of DRY weight-----
Your WET pin is 25% of total 5vr weight
Heavy pin ratio.....5vr should track very well w/o any chucking going on
Does it sit level when hooked up/nose high/nose low?
And how is your bed rail clearance----at least 6" (more is better provided 5vr is level)
Thanks for taking the time to get your actual weights and KNOW your are within ratings. Axle Ratings are the real world numbers one needs to pay attention to!
Super_Dave
Harrisville, UT
Posted: 04/22/20 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
My big question is how many trips across the scales does it take to get all that data?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
stickdog
Somewhere, USA
Posted: 04/22/20 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Most I could transfer weight to the front axel was 25#. As long as your not negitive your ok.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Cummins12V98
on the road
Posted: 04/22/20 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
My B&W is FULL forward, with my rear axle weight at least 9,750# my front axle only goes up around 150#.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 04/22/20 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
"Heavy pin ratio.....5vr should track very well w/o any chucking going on"
I can attest this is TRUE!!! 6k pin and that baby rides like it's on rails.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 04/22/20 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
allen8106, I have to ask where did you get the 3,719 - Max Cargo??
I have a 2018 High Country 3500 Dually and right from the door pillar mine is Payload 4930 Lbs.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
