RV.Net Open Roads Forum: Fifth-Wheels: First Cat Scale Weigh In
 > First Cat Scale Weigh In
Old-Biscuit
Verde Valley
Posted: 04/22/20 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
Super_Dave wrote:
My big question is how many trips across the scales does it take to get all that data?
TWO
One for Truck/Trailer combo
THen drop trailer and do truck alone
1st trip roughly $12
2nd weigh $2 if within 24 hrs at same location as 1st
allen8106
Burrton. KS
Posted: 04/23/20 08:01am Link  |  Quote  |  Print  |  Notify Moderator
JIMNLIN wrote:
-I found it interesting that the steer axle weight was the same with or without the 5ver hooked on.
I always set my GN and 5th wheel trailer hitch(s) to where it doesn't affect the trucks front axle much if any.
Your 4060 lb drive axle empty weight is one of the highest I've seen even on haulers websites. Is the 4060 lbs number as is from the factory or after you added your stuff in the truck.
The 4060 drive axle weight is all factory, no mods, just the stuff loaded in the bed, hitch, generator, flag pole, blue boy tote, driver, dog and cooler.
* This post was edited 04/28/20 08:30am by allen8106 *
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
allen8106
Burrton. KS
Posted: 04/23/20 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Heavy pin ratio.....5vr should track very well w/o any chucking going on
Does it sit level when hooked up/nose high/nose low?
And how is your bed rail clearance----at least 6" (more is better provided 5vr is level)
5th wheel tracks well and we only get a little chucking if we get some rough roads, otherwise it runs pretty smooth 95% of the time.
The 5th wheel sets a little nose high and bed rail clearance is about 5".
allen8106
Burrton. KS
Posted: 04/23/20 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Two, one with the camper on and one with the camper off. They will allow you to leave return as long as you return within 24 hours.
allen8106
Burrton. KS
Posted: 04/23/20 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Michelle.S wrote:
allen8106, I have to ask where did you get the 3,719 - Max Cargo??
I have a 2018 High Country 3500 Dually and right from the door pillar mine is Payload 4930 Lbs.
The max cargo came off the factory sticker in the glove compartment.
Cummins12V98
on the road
Posted: 04/23/20 09:21am Link  |  Quote  |  Print  |  Notify Moderator
2018 GMC 3500 DRW
9,375 - GAWR - Rear
5,600 - GAWR - Front
13,025 - GVWR
The above seems odd to me when my DRW that's 3 years older has these numbers.
2015 RAM DRW
9,750# RAWR
6,000# FAWR
14,000# GVWR
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 04/24/20 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Doesn't look like there was a question from the OP, just posting numbers from his first weigh.
I questioned why his 2018 3500 Dually had a cargo cap over 1000 Lbs lighter than mine.
And some others questions some of the other numbers.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
allen8106
Burrton. KS
Posted: 05/01/20 08:04am Link  |  Quote  |  Print  |  Notify Moderator
The numbers are off the placards/stickers placed by GM.
Michelle.S
Posted: 05/01/20 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, but there should still be another door label with the wording:
"Total weight of passengers and cargo should not exceed XXXX Lbs"
allen8106
Burrton. KS
Posted: 05/02/20 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Found this sticker, didn't originally see the print stating the capacity. Thought it just mentioned tires and pressures. I have updated my original numbers.
* This post was edited 05/02/20 10:17am by allen8106 *
