RV.Net Open Roads Forum: Tech Issues: 6 volt battery post melted
 > 6 volt battery post melted
Page of 5
larry cad
ohio
Posted: 04/24/20 05:39am Link  |  Quote  |  Print  |  Notify Moderator
ROBERTSUNRUS wrote:
[emoticon] Hi, melted connections are not caused by a short; They are caused by a poor connection. A heavy load with a poor connection creates heat.
Hmmm, I seem to recall from basic electricity that a short is a pretty heavy load. (Load being defined as amps)
Our Travel Blog
bid_time
Michigan
Posted: 04/24/20 05:43am Link  |  Quote  |  Print  |  Notify Moderator
That's what I was going to say Larry, you beat me to it.
Mmwtdh
Here
Posted: 04/24/20 05:52am Link  |  Quote  |  Print  |  Notify Moderator
I vote dead short..
pyrosecur
Montreal
Posted: 04/24/20 07:59am Link  |  Quote  |  Print  |  Notify Moderator
That is what I thought too, so I disconnected all the battery cables (including the chassis + & - ) and leave only the negative on the 6 v house battery, when I connect the positive (what I believe to be the generator cable it starts to smoke. there should be no load, that is why I think it is shorting and may have something to do with the boost/jump relay that I would like to test if I could find it.
Happy Camping ">
Allegro 32BA
pyrosecur
Montreal
Posted: 04/24/20 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Beverley&Ken wrote:
As for the original question, follow the problem positive cable and look for a place where it may be pinched, or worn insulation causing a dead short to ground. It may be where it goes through a metal wall and grommet is broken or missing, or along a frame rail or other metal grounded component.
Ken
Yes this was my first thought as well, I have started to try and follow it but this is quite a task with all the installation and the fact I have to crawl under the motor home and we are still having freezing weather here in Montreal. I'll keep looking....
azrving
Oatman
Posted: 04/24/20 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Take it to a repair shop or call a mobile tech. Its going to be far safer and cheaper than having it catch on fire
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 04/24/20 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
I have passed 1,000 amps through these terminals
wolfe10
Posted: 04/24/20 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
If clean and tight-- yes.
Loose, corroded, copper wire turned into copper oxide-- not so much.
Again, resistance times current= HEAT
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
MEXICOWANDERER
Posted: 04/24/20 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly my point
MEXICOWANDERER
Posted: 04/24/20 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
1,000 amps will flame anything smaller than 1/0 cable
Page of 5
