RV.Net Open Roads Forum: Fifth-Wheels: BIL with Superglide drops his trailer
 > BIL with Superglide drops his trailer
schlep1967
Harrisburg, PA
Posted: 04/27/20 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Me Again wrote:
schlep1967 wrote:
Just a general reminder to all 5th wheel owners... If the battery in the trailer is dead, you most likely have a good one in the truck you are trying to hook up. Use jumper cables and raise the trailer to the height you need it. Leave it just a little low so the weight lifts off of the legs when you hook up. Then pull the pins and raise the legs for travel.
I have cables long enough to reach the trailer battery when hooked up so I could raise the legs after being hooked up.
Also, in the two times I have had to do something like this to unhook, both time I forgot to unhook the umbilical cord before pulling out from under the trailer. Especially after doing something unusual when hooking or unhooking, start over and walk through your normal steps before proceeding.
Jumpering off these new trucks with all their electronics is not a very wise thing to do, plus the chance of blowing alternator diodes.
Tell you what, compare the motor size on your landing gear to the starter on your truck. As long as I am intelligent enough to hook up the cables correctly, I have no fear of hurting a truck by jumping another 12 volt system.
Unless of course you can show me in the manual where it says you shouldn't do it.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
thomas201
Eastern Panhandle WV
Posted: 04/27/20 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
X3 Get out, bend over and look with a flashlight. Check that the pin is captured by the fifth wheel. You may be high hitched, or maybe submarined the pin (pin rode up and over, dropped in front of the fifth wheel). Do it the same way every time. Don't let people or events distract you. Checklists are good, if you use them.
Super_Dave
Harrisville, UT
Posted: 04/27/20 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Plugging the power cord into the 7 pin plug while the truck motor is running has always been enough juice to raise and lower my front jacks when the battery is dead.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
C.B.
APPLETON WI USA
Posted: 04/27/20 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with ford truck guy.
17 years on my 16K Superglide without a problem.
Two things I religiously look at when hitching.
Handel is all the way in and locked.
Latch is wrapped around king pin.
Latch on Pullrite wraps around the king pin not just a bar across.
Have never had an issue with unhitching.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
MNRon
Tennessee
Posted: 04/27/20 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
Same as comments above. I've pulled with a Superglide for 6yrs and 50k+miles and love the hitch. Can't believe it was anything but operator error.
Look to make sure pull lever in all the way in, check to see that wrap-around jaws are around kingpin and that you're not high-hitched. If you do both of these things I can't imagine how the Superglide could fail. Maybe there's a way, but I can't imagine it.
Always double-check the wrap-around covers the kingpin and not high-hitched, ESPECIALLY if it's been a while or you're distracted.
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
Bird Freak
Dallas Ga.
Posted: 04/27/20 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have also used a SG for years. When you hear it snap in its locked.
Thing that caught my attention was he said he moved a friends trailer before.
Did it have the SG plate on the pin box? It had better!
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
bobsallyh
Livingston, TX.
Posted: 04/27/20 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Certainly did not do the jerk test!
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 04/27/20 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Has nothing to do with the landing gear motor. It is the surge of current hooking the truck to the dead batteries in the trailer or another vehicle.
Ford Edge ST Twin Turbo 2.7L V6 335HP and 380 Lb Ft - Summer Home 2017 Bighorn 3575el. Can Am Spyder RT-L Chrome. Retired and enjoying it!
Me Again
Posted: 04/29/20 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
NOPE, just a king pin hanging down. Why would that matter? Just would not do the auto slide???
ford truck guy
Pennsylvania
Posted: 04/29/20 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Correct, A few have "locked out" their SuperGlides and removed the capture plate for different reasons with no issues.. Me being 1 of them
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
