RV.Net Open Roads Forum: Resealing the Edge of the Roof, Dicor, Eternabond, or Both?
 > Resealing the Edge of the Roof, Dicor, Eternabond, or Both?
crcr
US
Posted: 05/02/20 09:42am Link  |  Quote  |  Print  |  Notify Moderator
I'm about to do some re-sealing to the roof edges on our travel trailer, to ensure no water damage. Attached find two images of the edge of the roof. I have a tube of Dicor Non-Leveling, Non-Sag Lap Sealant, which I have had very good luck with in the past. The TT is a 2011 model if that matters.
Where the roof material comes over the edge of the roof, you can see in some places there is cracking and slight separation of old caulk. I would like to cut and remove the separated caulk before re-caulking, but I am very concerned that it will be hard to do that without scoring or cutting the roofing material underneath.
So do you think I should just run a bead of my Dicor along there to cover and refresh the old caulk? Or should I instead overlap the edge with some Eternabond tape? Or, should I perhaps refresh the caulk AND then once cured, apply Eternabond over the edge?
Looking for any suggestions or advice with this project. Thanks in advance!
[image]upload pictures internet
opnspaces
San Diego Ca
Posted: 05/02/20 10:06am Link  |  Quote  |  Print  |  Notify Moderator
It might come up without cutting it just grab and pull. I've been able to use that method of two different RV's and it works fairly well. If it is a real bear to pull up I would just caulk over it. I have used and like Eternabond, but I've never wrapped it around an edge like where you have the cracking.
As far as the big puddle of caulk in the back corner, I would definitely caulk over. It looks like there is a low point there and the manufacturer filled the area with caulk to prevent a standing water puddle that would be more prone to leak.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Bishop area, California
Posted: 05/02/20 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Regarding picture number one, remove all you can, use Dicor self leveling, let it cure and then tape.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
mrquacker
iowa
Posted: 05/02/20 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Watching this, 'cause I gotta do the same this.
TurnThePage
North ID
Posted: 05/02/20 11:27am Link  |  Quote  |  Print  |  Notify Moderator
I wrapped Eternabond all the way down to the gutter on my trailer about 15 years ago. It's been more or less bullet proof. The only caulk I removed was to give the tape a smooth surface to adhere to. I glommed a couple layers of tape over the those corners, then used a little self leveling caulk on the edges.
2015 Ram 1500
2004 Pioneer 18T6
crcr
US
Posted: 05/02/20 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone, for all your responses! Much appreciated!
jdc1
Rescue, Ca
Posted: 05/02/20 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Yep. It's easier to wait for a warmer day. It's more pliable. Use a flexible putty knife to remove the old caulk.
phemens
Montreal, Canada
Posted: 05/02/20 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Same here, went around all the edges of the roof with Eternabond, it comes halfway up from the gutter, 4" tape. 1st thing I do on any RV I get.
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1200w solar, 600AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
mleekamp
Washington, IL
Posted: 05/03/20 05:12am Link  |  Quote  |  Print  |  Notify Moderator
The last 2 units we bought (a TT, then our C in late 2018), one of the first things i did was use a roll on the roof at all seams...where vents/skylights are, and on edges front and back. Why? Got tired of small leaks here/there on an older unit, and when i just Eternabonded the seams on that roof, it stopped. Now, I feel the time/cost is worth it up front.
2019 Jayco Redhawk 29XK Class C, Ford V10 E450 with Roadmaster Hitch Mounted Spare Tire holder, Bigfoot Hydraulic Leveling
Dinghy: 2021 Ford Ranger XL
rhagfo
Portland, OR
Posted: 05/03/20 06:36am Link  |  Quote  |  Print  |  Notify Moderator
No Self leveling on a vertical surface, us non sag. I use plastic scrapers to clean off old calk on the roof, with rounded corners and work carefully.
