RV.Net Open Roads Forum: Resealing the Edge of the Roof, Dicor, Eternabond, or Both?
 > Resealing the Edge of the Roof, Dicor, Eternabond, or Both?
ksg5000
Oregon
Posted: 05/03/20 06:59am Link  |  Quote  |  Print  |  Notify Moderator
I elected to use Eternabond along all the edges in my Class C many years ago - my 91 is still leak free. When you apply eternabond pay attention to the "prep" work as it requires a clean surface to properly bond. You should remove the loose caulk ... if you elected to remove all the caulk (not mandatory) I would recommend that you use an oscillating tool with a special caulk remover blade (rounded flexible blade that isn't sharp and won't harm roof membrane).
Kevin
beemerphile1
Ohio
Posted: 05/03/20 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Those that take Eternabond over the edge to the gutter - did you remove the plastic screw cover or leave it in place?
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Carvhors
Ohio
Posted: 05/05/20 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
I removed it. This allows the Eternabond to also seal the screwheads that are holding the aluminum gutter/trim on.
Carvhors
Ohio
Posted: 05/05/20 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
