RV.Net Open Roads Forum: Travel Trailers: Sway Problem / Need Help
 > Sway Problem / Need Help
Page of 5
opnspaces
San Diego Ca
Posted: 05/09/20 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
mikeratz wrote:
From the reviews I looked at I like the Equalizer. It's also a lower profile and my trailer is fairly low (the Reece dual cam does hang down a bit. Had one a few trailers ago)
Also according to the Equalizer website you only add behind the axle cargo weight? (I've always used all passengers and truck cargo)
Slowmover wrote:
Of the obsolete hitch types (non-Hensley patent) the original WDH is still the best. The Reese Dual Cam. (An Equalizer IS NOT in its class).
You have to read the replies above carefully as there is a difference between an equalizer hitch and an Equal-i-zer hitch. The equalizer hitch is a generic term used for describe the original round bar weight distribution hitch with no built-in sway control. In that sense Slowmover is correct that an equalizer hitch is not in the same class as a Reese dual cam.
The brand name "Equal-i-zer" hitch however is not just a standard equalizer hitch. The Equal-i-zer is in the same class as the Reese dual cam hitch and both incorporate built in sway control and weight distribution in the hitch.
Then there is the Hensley Arrow (HA) or the Propride hitches. These two hitches are in a league of their own and their price ~ $2000 reflects that.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Slowmover
Fort Worth, TX
Posted: 05/09/20 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Equalizer brand NOT as good. Period.
1990 35' SILVER STREAK Sterling, 9k GVWR
2004 DODGE RAM 2WD 305/555 ISB, QC SRW LB NV-5600, 9k GVWR
Hensley Arrow; 11-cpm solo, 17-cpm towing fuel cost
mikeratz
Alberta
Posted: 05/09/20 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
So loaded it back up today for the season and grabbed some new weights. Some improvement but still 200# removed from front axle. Moved some weight around and dropped hitch from 1080# to 1014# but looks like that's as low as I'll get it. Total trailer weighed today was 6800# so still 15% on hitch.
Leaning towards a Equal-i-zer hitch.
Some concerns posted that a 1200#/12000# might be too much for my truck hitch. It doesn't have a rating sticker on it but it is a max tow and from what I can find it should be 13000#??
Is a 1200# ok?
* This post was edited 05/09/20 08:10pm by mikeratz *
TomG2
Central Illinois
Posted: 05/09/20 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with the Ford and GM engineers who don't get all hung up on front axle weight restoration as some of our contributors continue to do. Read the latest manuals if you don't get it. That does not mean that the various ratings do not matter, The engineers still specify those.
I am one who likes a more than adequate tow vehicle with little dependence on trick hitches, oversize tires, weight tweaking, and suspension upgrades. The manufacturers build some great tow vehicle. Ever see anyone come on here complaining, "I have too much tow vehicle, I want to feel that trailer back there"?
LarryJM
NoVa
Posted: 05/11/20 06:06am Link  |  Quote  |  Print  |  Notify Moderator
And that statement is Pure BULL ... PERIOD! PERIOD!
Both the Equal-i-zer and Reese Dual Cam are performance wise equal to one another when properly set up and matched to the TT loads and the choice is a matter of personal preferences.
The one single adavantage of the Reese is that it can be had in a 1700lb TW version whereas the Equal-i-zer maxes out at 1400.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
Slowmover
Fort Worth, TX
Posted: 05/11/20 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Larry
Shock load on receiver. Equalizer inferior. Crude
01tundra
Middle, TN
Posted: 05/13/20 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Slowmover wrote:
An Andersen shouldn’t ever be considered if a WDH is needed. It isn’t one.
An Andersen No-Sway WEIGHT DISTRIBUTION hitch is exactly that, a weight distribution hitch that also incorporates sway control.
I've used one for several years with a few different trailers and tow vehicles. It may not be as efficient at returning weight to the front end of the tow vehicle when used with heavy trailers (i.e., tongue weights greater than 1,000 lbs), but for sub 1,000 lb tongue weights the hitch works wonderful and it absolutely is a weight distribution hitch.
2020 Rockwood Mini Lite 2109S
2017 GMC 2500HD Denali Duramax
djsamuel
Central Florida
Posted: 05/14/20 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Seriously? The Andersen is a great WDH in the proper applications. In applications where there is a high tongue weight and a lot of redistribution is required, then the Andersen is not the best choice. However, for many applications the Andersen is an outstanding choice. It's worked great for me over the last 6 years.
Picture of Our Trailer
Camplite 21BHS
jerem0621
Tennessee
Posted: 05/14/20 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Supercharged, is that you?
TV- 2011 Chevy Tahoe, 2WD, Hayden transmission cooler
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
Tekonsha Voyager brake controller (Great Brake Controller)
It’s Kind of Fun to do the Impossible
~Walt Disney~
Slowmover
Fort Worth, TX
Posted: 06/07/20 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
It offers nothing in sway resistance that the cheapest WDH doesn’t already have, and it FAILS by definition in distributing tongue weight.
Where are the scale tickets? CAT Scale. Three-Pass Method. See Ron Gratz post from 2010. Full fresh water & propane in trailer. Loaded for camping. TV with fuel topped off at truckstop, loaded for camping, all passengers aboard.
Do that procedure and post them.
Check tire pressure before heading to scale. Overnight cold. The scale values are how to dial in pressure correctly. From the Load & Pressure Table, but inside TV door sticker range.
Pic of axle/tire/wheel limit sticker.
Trailer needs to be dead-level once hitched and everyone aboard plus all liquids/gases topped off. Carpenters level across doorway. In, or mainly inside bubble.
— One of several tests of WDH is braking. It the combined rig DOESN'T stop faster than the loaded truck, solo, you’ve not gotten the hitch rigging right.
— Absent crosswinds, you should be able to “let go” of the steering wheel for at least a three-count. (1001, 1002, etc) without heading for the ditch.
— Passing traffic should have little effect. Minor, gradual, steering correction (singular, not plural) is the mark.
— Solid-axle 4WD pickup is the worst TV.
Ideally, the truck balances very closely to 50/50 FF/RR in weight BEFORE you hitch the trailer. Anything heavy in the bed (the same problem exists with the front axle) is ON or AHEAD of the Drive Axle. No exceptions. It’s ALSO secured against ANY movement. None of this is optional.
(My ‘04 Dodge is 8,940-lbs and within 40-lbs at all four corners. It was a pain to get it there as it remains loaded, always. The point is to get it right, get proper storage containers, lash down, and take some pics for reference).
— What’s the weight of yours when solo at this point (per axle) as against the limits?
The addition of TW (a static value; meaningless except as starting reference) SHOULD see the Steer & Drive Axles split the difference of 75% of TW. With about 10% more to the Drive Axle once done.
Extra spring capacity — unused — is detrimental. Means the Drive Axle is MORE LIKELY to get loose, even airborne, if that TT decides to get frisky. Keeping that set of tires in contact with the ground — then losing it momentarily— IS the reason that pickups have their poor safety record.
Upgrade the shocks today. I wouldn’t take it home from the dealership brand-new without this. Tires can’t control the springs (and if you have overinflated tires, even less so), and better shocks are first step. Second is replacing FF/RR anti-roll bar rubber bushings with polyurethane. They don’t give or wear. Those bars act sooner and more consistently.
Your TV needs issues addressed before a WDH can be best understood.
A WDH that can’t leverage TW is NOT a Weight-Distribution Hitch. It may be light in weight, etc, but as it offers no more sway resistance than the cheaper offerings, it’s an expensive way to have gotten next to nothing.
A 350-lb TW is where a WDH starts to become useful. So unless your trailer is 4,000-lbs, the Andersen is a really poor choice. As it hasn’t leverage enough BY DESIGN.
Get the baseline numbers. Do it correctly.
Address the truck problems.
Minimize problems with what you own, now.
* This post was edited 06/07/20 02:22pm by Slowmover *
Page of 5
