RV.Net Open Roads Forum: Travel Trailers: Andersen hitch
 > Andersen hitch
Page of 5
Snomas
Sedona, AZ
Posted: 05/13/20 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
I have one and its does what it says: quiet, easy to set up. My tongue wt is 525lb and the Trailer is about 6000#. I do think I need a new sleeve and you don't want to grease the ball.
2018 F150 Lariat Crew Cab, 5.0 L V8, RWD.
2019 Flagstaff micro mini 21DS
Anderson WDH
CavemanCharlie
Storden,MN
Posted: 05/15/20 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
I have one and love it. It is easy to install and use.
I do have a lighter Travel Trailer though.
I towed my TT for years without one at all actually. This Anderson makes it tow better and the truck rides better.
Flapper
Minnesota
Posted: 05/15/20 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
I had one, and the only real issue was that it is not suitable for big trailers. Mine's 34 ft, with a tongue of 900+. I was easily able to get full weight transfer back to the front of my F-150. But, with that long of a trailer, it is easy to overpower the friction in the cone, so wind/truck suck were bad. Great concept, and I wish it would have worked out for me. For those with small to mid-size, I would recommend.
2012 F150 Eco, 4x4, SCrew, Max Tow, HD Payload
2017 Grand Design Imagine 2670MK
mr_andyj
Georgia
Posted: 05/16/20 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
The red urathane bumper is the spring, so it does have a spring, a red urathane spring.
For those that have one... How much angle difference between the truck and trailer can be had? The red bumper is short, so the spring travel will be small, and when it bottoms out that is it. With bar springs they will keep bending or the trailer frame will bend, but mostly the spring bar will bend as needed.
Or what happens if you go too far? Will the bolt-on mount just twist forward and no harm other than having to re-set it?
GrandpaKip
Flat Rock
Posted: 05/17/20 09:38am Link  |  Quote  |  Print  |  Notify Moderator
I really can’t say how much of an angle it will take. The urethane bushings is compressed about 1/4” on my setup. Again, I have no idea how much it can be squeezed.
I do know that it has never moved the brackets, deformed anything or stopped us from going anywhere.
However, we don’t go trooping through the outback, crossing gullies, fording rivers, etc. We have been on some pretty rough and twisty roads out west that limited us to 10 mph or less.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
GT928
North Georgia
Posted: 05/18/20 06:19am Link  |  Quote  |  Print  |  Notify Moderator
We replaced our old WDH with an Anderson a couple years ago. Night and day difference in all respects. Quiet, smooth and no jerking. Easier to hook up. There is no way I would go back. We are pulling a 29.5' Earthbound with a 2013 Jeep Grand Cherokee.
2011 Earthbound Golden Ridge
2013 Jeep Grand Cherokee Overland
North Georgia
djsamuel
Central Florida
Posted: 05/18/20 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Never had an issue with that over the many places we've gone with the hitch. I would add though, that unlike springs which have a more consistent spring constant, the urethane "springs" resist compression more as they are compressed. So while they may compress easily at the beginning, they become more difficult to compress as the force is increased. I think this is what helps prevent the urethane from "bottoming out".
Picture of Our Trailer
Camplite 21BHS
ajriding
st clair
Posted: 05/18/20 09:13am Link  |  Quote  |  Print  |  Notify Moderator
That is what is called a progressive spring rate. The bars have a more linear spring rate, and a linear spring rate is better in this situation.
I also tend to end up at rough places, dirt roads that get worse near the camping spot, so I have to take the bars off before I get there. The bars are easy as I just use a lever to unload the spring, but the Anderson requires jacking up the tongue?
TomG2
Central Illinois
Posted: 05/18/20 10:00am Link  |  Quote  |  Print  |  Notify Moderator
ajriding wrote:
....sipI just use a lever to unload the spring, but the Anderson requires jacking up the tongue?
Not getting very much weight distribution if the bars are that easy to remove. I am no weakling but lifting the tongue helps me.
TomG2
Central Illinois
Posted: 05/18/20 10:17am Link  |  Quote  |  Print  |  Notify Moderator
ajriding wrote:
rhat is what is called a progressive spring rate. The bars have a more linear spring rate, and a linear spring rate is better in this situation.
Do you have some actual engineering to back that up or just a guess because it it not what you have? What is wrong with a little resistance when that is all that is needed and more as the load increases? That may well be one of the reasons that many actual Andersen users comment on the improved ride and less porpoising.
Page of 5
 > Andersen hitch
