RV.Net Open Roads Forum: Beginning RVing: Rear View Camera vs Backup Camera
 > Rear View Camera vs Backup Camera
Wherever I happen to park
Posted: 05/27/20 05:11am Link  |  Quote  |  Print  |  Notify Moderator
All I can do is tell you about mine
By default it is a "Back up camera"
but there is a button (4 or 5 of them)
The top button is POWER and if I press it. it's a rear view camera
The next button is A/B and if I press it.. Well the side view camera is not currently working (It's under the gas cap to help me line up on a pump. got to fix it one of these days)
I am thinking about the RV-360 system
https://www.rearviewsafety.com/hd-360-camera-system-with-built-in-dvr-rvs-77555.html
But have yet to make the purchase
Home is where I park it.
Elk_traveler
maryland
Posted: 07/29/20 07:34am Link  |  Quote  |  Print  |  Notify Moderator
sailmike1 wrote:
I'd just like some clarification on this topic. Every time I do a search for a rear view camera, I get a list of backup camera's. I'm looking for a camera and monitor that's on all the time, not just for backing up my vehicle. I can't find any information to clarify this.
Are all backup camera's only for backing up?
How do I find one to replace the rear view mirror to use for normal driving?
Thanks,
Puzzled
I mounted a separate camera with wide angle lens at very back end of roof that I can switch on and off at will connected to battery. I use a 7 inch monitor mounted on dash of vehicle that delivers a 1080p image to monitor. I am able to see everything behind me as well as on both sides. The only difficult part was stringing the wire down and under the chassis of the motorhome to the engine compartment battery. I previously did this on a 5th wheel and used a disconnect switch in-line when unhooking the 5th wheel. There are numerous cameras around and any back up camera will do this if wired to the battery instead of tail lights. There are wireless camera available but I don't think always dependable because of wireless interference. Its better to wire the camera so there is no problem with always seeing what's on the road behind you. My RV has a factory back up camera installed but I too want to see the road and the traffic on the sides. This set up is worth its weight in gold when you're on the interstate such as I-80, I-90 or any other and and especially when coming in and out of toll booths with so much traffic. New cameras are available that have high resolution such that you can read license plates of vehicles behind you very well.
