RV.Net Open Roads Forum: Beginning RVing: Rear View Camera vs Backup Camera
 > Rear View Camera vs Backup Camera
Bobbo
Wherever I park
Posted: 05/13/20 07:51am Link  |  Quote  |  Print  |  Notify Moderator
I second the idea of powering it from the clearance lights. A wire is already in the area, you don't need to mount an additional switch, the camera isn't on all the time, and it is easy enough to turn on when you want it by merely turning on the parking lights. My Airstream come with a rear view camera powered exactly that way.
Bobbo and Lin
tropical36
Southwest Florida_USA
Posted: 05/13/20 08:10am Link  |  Quote  |  Print  |  Notify Moderator
sailmike1 wrote:
I'd just like some clarification on this topic. Every time I do a search for a rear view camera, I get a list of backup camera's. I'm looking for a camera and monitor that's on all the time, not just for backing up my vehicle. I can't find any information to clarify this.
Are all backup camera's only for backing up?
How do I find one to replace the rear view mirror to use for normal driving?
Thanks,
Puzzled
They're all one in the same, as far as I know.
Mine comes on when in reverse, but if you manually turn it on, which I always do, then it's on all the time.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
cougar28
Lowell,AR USA
Posted: 05/13/20 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Not all backup cameras are to be used as observation cameras. Some are not designed to be left on for extended times or the camera with burn out.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
Harvey51
Alberta
Posted: 05/18/20 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Another vote for a switch. I mounted the switch on the base of the driver’s seat so I can conveniently reach it to power the camera and monitor. My first camera was designed for a license plate mount but I soon put it on the inside of our class C looking through the top of the rear window, adjusted so I can just see the hitch on the kayak trailer and most of a campsite when backing in. I can safely back up to well within a foot of the trailer or a tree. With the camera angled about 45 degrees down the horizontal distance is easy to judge. I can keep good watch on the kayaks on the highway.
On our first trip with the camera we actually used it when camped in a remote campsite On the Grande Cache highway in Alberta. A few inches of snow on the ground making it easy to see a fox visiting our site without scaring it away.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
4x4van
California
Posted: 05/20/20 10:11am Link  |  Quote  |  Print  |  Notify Moderator
No switch is needed; simply power it off of a wire that is hot with the ignition rather than from the backup lights.
Mine comes on in reverse, but has a manual switch on the monitor that turns it on constantly. That's how I use it.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 BW200, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
sailmike1
Earth
Posted: 05/21/20 09:45am Link  |  Quote  |  Print  |  Notify Moderator
How would I connect it to that wire?
Thanks!
rwgeiser
Anchorage, Alaska
Posted: 05/21/20 10:55am Link  |  Quote  |  Print  |  Notify Moderator
When I installed my camera for my backup monitor I actuated it with power from the backup light circuit with a .5 amp resistor in line. I also ran a 12v feed down stream from the resistor, with a switch that I can power the camera at any time. It does not backfeed the backup light circuit. I have a GPS that I also use as the monitor.
Ron & Del
2003 Fleetwood, Storm 30H
P32 Chassis
Part-Timer, Retired
DrewE
Vermont
Posted: 05/21/20 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
I believe you mean a diode, not a resistor.
Dutch_12078
Winters south, summers north
Posted: 05/21/20 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
Like Tropical36, my rear camera monitor is wired to come on in reverse unless I turn it on manually where it stays on. Once I turn it on, it remembers that setting the next time I start the engine until I turn it off. I installed two rear cameras that I can select at the monitor, one aimed low that lets me see from the motorhome rear bumper back about 20 feet, and the other aimed high enough to see back down the road. The low camera is handy for backing into tight sites as well as checking on my toad hookup while under way.
Dutch
2001 GBM Landau 34' Class A
4x4van
California
Posted: 05/26/20 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
Depends on the unit. If the unit you purchase has only one wire for powering the camera/monitor, you use a wire that is hot when the ignition is turned on instead of the backup light wire.
