RV.Net Open Roads Forum: Any advice for replacing exhaust manifold gasket in a 454?
 > Any advice for replacing exhaust manifold gasket in a 454?
atikovi
Suburban Washington DC
Posted: 05/13/20 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
On my 1988 Southwind the driver side is leaking and wont pass inspection. I have a 1989 P30 factory service manual but it pretty much just says to remove spark plugs, remove exhaust pipe, remove manifold bolts and plug shields, remove manifold. I'm sure it's more involved than that.
lryrob9301
Mid-Atlantic
Posted: 05/13/20 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Given the age of your vehicle, every nut, bolt and screw will be rusted tight. Get lots of penetrating oil, a top quality set of drill bits, and stud and bolt extractors. You will undoubtedly run into broken bolts and fasteners when you try to loosen them. Also get a good supply of top grade nuts, bolts, and studs for replacement.
2013 Tiffin Phaeton 40QBH
2016 Chevrolet Equinox LTZ AWD V6
jdc1
Rescue, Ca
Posted: 05/13/20 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
Bandaides. Plenty of bandaides for the knuckle-buster bolts.
atikovi
Posted: 05/13/20 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Should it be hot or cold when removing the bolts?
Gjac
Milford, CT
Posted: 05/13/20 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
The best advice I can give you is don't just replace the gasket, replace the exhaust manifolds with headers. If you look very carefully the stock manifolds are probably cracked anyways. The old 454's and 460's run hot anyways and tend to crack and burn spark plug wires also. I would also replace the ign wires with Hi temp 10.4 MM wires like the Taylor Extreme wires while you are at it. Your engine will run a lot cooler and the fan clutch will come on lest often, not to mention increasing your HP between 60 and 80 HP. If you plan to do the job yourself soak the bolts every day for a week with Kroil oil and tap each bolt head each day to set up a capillary action to get the oil into the threads. If the bolts won't come out or break off, I would let a garage do it.
* This post was edited 05/13/20 03:17pm by Gjac *
theoldwizard1
SE MI
Posted: 05/13/20 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Get a hold of Ivan at Pine Hollow Automotive in PA !
(P.S. I agree, the manifolds are likely cracked.)
atikovi
Posted: 05/13/20 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
I'm selling it so need the simplest thing that will pass inspection.
K Charles
Connecticut
Posted: 05/13/20 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
your selling it. Get it hot, mix up some furnace cement, or buy some pre mixed, and but it on the leak. Let it dry before starting.
atikovi
Posted: 05/13/20 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
I thought they were stainless steel?
atikovi
Posted: 05/13/20 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
For a blown gasket?
