RV.Net Open Roads Forum: Fifth-Wheels: Awning tie downs
 > Awning tie downs
M.R.E.
MI, usa
Posted: 05/14/20 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Columbus 5th wheel with an electric awning that I tie down with ratchet straps. I was told you shouldn't do this because you can bend the tube unless you have a spring mounted on the end of the straps. Is this true ?
toolmaker
schlep1967
Harrisburg, PA
Posted: 05/14/20 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
Unless your ratchet strap is in the middle of the awning, and I have no idea how you would do that, you can't bend the tube. Now if you decide to go crazy ratcheting it tight with a strap attached to each end of the tube, you could literally pull the support arms off the trailer or bend the arms.
Or do like I did.... I ratchet strap from the ends of the tube back to the trailer frame on the front end and the trailer wheel on the back of the awning. My mistake was I did this before putting out the living/dining room slide. When the slide got put out it bent the arm on the awning.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
M.R.E.
MI, usa
Posted: 05/14/20 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have a strap on each end anchored to screw in anchors in the ground.
enblethen
Moses Lake, WA
Posted: 05/14/20 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
I would be more concerned about putting pressure on the gear assembly then bending the tube.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
cummins2014
Utah
Posted: 05/14/20 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Just not a good idea , things get bent in the wind. I never leave mine when it’s out , and if it starts to get a little windy we bring it in . Seen too many get ruined in the wind . Ju
laknox
Arizona
Posted: 05/14/20 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
Gimme manual awnings, any day!
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
md_procouple
Parkville, Md.
Posted: 05/14/20 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
I use the ratchet tie downs as well, and have springs attached to the screw ground anchors Have not had a problem in 12 years and have been thru a couple of wind storms
Vickie, Me, and "Scruffy" our dog make THREE
rhagfo
Portland, OR
Posted: 05/14/20 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Well not an electric awning, but 21’ manual awning and three ratchet straps one at each end and one in the middle. The one in the middle is attached using two of the straps in the link. All straps just snug, awning out almost 24/7/365 as we are full time park host. If wind gets too bad I will take it in, but not too often.
Link
cummins2014
Utah
Posted: 05/14/20 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
Lyle
I’ve seen a couple pretty healthy men nearly lifted off their feet trying to get a manual awning in when the wind suddenly come up in Montana , when mine was already in pushing the electric switch . I’ve had both ,and I have to say I’ll stick with power awnings .
ford truck guy
Pennsylvania
Posted: 05/14/20 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Why tie it down >??? Just hit a button and retract it if leaving... If it's windy... whenever...
I used to tie my manual awning down, will not tie my electric awning down, it's just too easy to put it in.....
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
 > Awning tie downs
