RV.Net Open Roads Forum: Tech Issues: 30amp / 50amp question
 > 30amp / 50amp question
tarnold
georgia
Posted: 05/15/20 06:47am Link  |  Quote  |  Print  |  Notify Moderator
If I recall, on my PC when plugged into 30amp the second a/c is not receiving current thu the panel, so it can’t be turned on.
Kpackpackkelley
Bryan tx
Posted: 05/15/20 06:57am Link  |  Quote  |  Print  |  Notify Moderator
Should be able to draw 30 amps any combination of loads.
theoldwizard1
SE MI
Posted: 05/15/20 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Concur, IF the adapter connects both hot legs of he 50A plug to the one hot leg of the 30A plug.
wolfe10
Posted: 05/15/20 07:26am Link  |  Quote  |  Print  |  Notify Moderator
100% of the 30 male to 50 amp adapters I am aware of DO connect the single hot on the 30 amp end to BOTH hots on the 50 amp end.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Bobbo
Wherever I park
Posted: 05/15/20 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Depends on how the manufacturer wires the RV. That is not a generally safe assumption to make. A lot, if not most, manufacturers merely put them on separate legs of the breaker panel. Since both legs get power with the 30 to 50 adapter, it is entirely possible that both ACs could be turned on. The manufacturer would have to put in something to detect that it was only 30 amp power, and disable the second AC.
Bobbo and Lin
Kpackpackkelley
Bryan tx
Posted: 05/15/20 09:55am Link  |  Quote  |  Print  |  Notify Moderator
Two ac ‘s should be around 30 amps or do they pull more than that.
2oldman
Mecca
Posted: 05/15/20 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
They pull 5x that much on starting up, but yeah, 30a is about right.
The problem here is that a "30a" system doesn't mean you should be running at 30a continuously. That means max, at least that's been my experience. You run a significant risk of overheating your plug when you do that.
It's like running a 2kw generator at 2k all the time. Ain't designed for that.
Kpackpackkelley
Bryan tx
Posted: 05/15/20 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
So # 10 wire and a 30 amp breaker and plug can’t be run at 30 amps continuous.
Do you have to bigger wire or plug or breaker. Plug , wire and breaker are not a generator with a motor ..
2oldman
Mecca
Posted: 05/15/20 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
The problem is the plug and socket. Most sockets have some kind of corrosion, causing a poor connection and heat. The point of connection of the wires to the plug are also a weak point.
Your mileage may vary.
Kpackpackkelley
Bryan tx
Posted: 05/15/20 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Ok I see what your saying . I talking about I guess perfect conditions which we won’t have. That reminds I should clean my plugs. They do get tarnished .
Anybody ever clean them with brass cleaner then wipe them with alcohol thinking of trying it. ?
