RV.Net Open Roads Forum: Tech Issues: 2019 Equinox Dead Batteries
 > 2019 Equinox Dead Batteries
Davisj9798
Se USA
Posted: 05/16/20 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Flat towing at 2019 Equinox behind 2008 Holiday Imperial. Have a charge line from MH to car (13 volts) via ToadCharge. Motorhome also has Daytime run lights which I think could be issue with battery drain to car. Diode kit from Blue Ox was installed with base plate. After 3 hours of tow, its a crapshoot if the car will start. Anyone have any suggestions or updated policy from Chevy?
Owens River Road, California
Posted: 05/16/20 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Your post is fine.. No need for help or support IMO. Try tech issues.
lryrob9301
Mid-Atlantic
Posted: 05/16/20 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Why are the Equinox daytime running lights on? If the ignition is in the OFF/ACC mode the lights will not be on. I believe your are towing the Equinox with the ignition in the ON position instead of the OFF or ACC position.
2013 Tiffin Phaeton 40QBH
2016 Chevrolet Equinox LTZ AWD V6
CA Traveler
The Western States
Posted: 05/16/20 11:09am Link  |  Quote  |  Print  |  Notify Moderator
With the car setup for towing and the MH running what is the voltage measured at the car battery posts?
2014 Grand Cherokee Overland
Bob
Ava
Vancouver Island. BC Canada
Posted: 05/16/20 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
The owners manual probably suggests to remove specific fuses when towing. There are disconnect switches available to make that easier
deltabravo
Spokane, WA
Posted: 05/16/20 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
The motorhome having DRLs should have no effect on the towed car.
2018 Timberridge 24RLS (bought pre-owned 3/12/20)
Davisj9798
Se USA
Posted: 05/25/20 04:25am Link  |  Quote  |  Print  |  Notify Moderator
No daytime running lights are on the MH. don't see anything extra on the car but twice the battery has been completely discharged. last time we couldnt even get back into the car because the door locks were dead. Had to have it towed to Chevy place. Said battery was dead, and they had to reset module (??) Charge line from MH has 13.2 volts. don't understand why battery is completely dead...
Davisj9798
Se USA
Posted: 05/25/20 04:27am Link  |  Quote  |  Print  |  Notify Moderator
2019 has no recommendation for pulling any fuses. Only the towing steps to and from recreational towing..
CA Traveler
The Western States
Posted: 05/25/20 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Apparently the chargge line is not getting to the battery. So again:
Also after hookup and before starting the MH turn on the car headlights for 10 min to remove any surface charge. At that point the car battery should be 12.7V.
