RV.Net Open Roads Forum: Beginning RVing: Adding a 12v outlet
 > Adding a 12v outlet
er78mph
Chula Vista, CA
Posted: 05/16/20 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I wanted to tie in a 12v outlet at the panel/converter but there is no additional space. The location is really convenient. I was wondering if I can just tap in the the negati e/positive bus behind the panel in order to make this happen? I'll also add an inline fuse. I would just be using the outlet for low watt items. Thanks all in advance!!
DrewE
Vermont
Posted: 05/16/20 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
I think it would be better to simply tie into an existing 12V circuit that seems appropriate.
opnspaces
San Diego Ca
Posted: 05/16/20 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, but with caution. Remember that you are not connecting to the circuit breakers (which are AC) so more than likely there is no BUS to help you out.
You are connecting to the fuses which typically are powered by a single, heavier gauge wire into the back of the fuse panel.
From the fuse panel you will then have a bunch of smaller fused wires out to the various 12v applications. You should be able to isolate a single 12v wire (I've used overhead lights in my trailer) and tap into that wire for your 12v positive. By going this route you probably do not need a fuse as the wire you tapped into is already fused at the panel.
As far as the negative, you might get lucky and the fuse panel also has a connected ground wire. If no ground wire then you can run a separate ground wire to somewhere. This is where a multimeter to check continuity comes in really handy. It might be possible to tap into the ground BUS on the AC side of the breaker panel. But this is typically advised against. You really want to find a ground location that is a bit isolated from the AC side of the system.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
er78mph
Chula Vista, CA
Posted: 05/16/20 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Okay, that makes sense! Thanks for your help and feedback!!
Wherever I happen to park
Posted: 05/17/20 05:18am Link  |  Quote  |  Print  |  Notify Moderator
er78mph wrote:
Hello,
Short answer is yes so long as you remember the fuse.
I have extra fuse slots in my panel and have added several additional outlets. Some wired back to the panel (3) some (3 more) tapped into existing circuits that had the current carrying capicity and a proper fuse.
Home is where I park it.
er78mph
Chula Vista, CA
Posted: 05/19/20 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
So I found a wire running to a 15Amp fuse at the panel for the "living area" and "exterior lights". Would it be okay to tap into this wire for my 12v connection?, thanks!!
Posted: 05/19/20 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Yes but remember if you turn on too many lights it will be lights out when you plug into that outlet.. Of course if you convert to LED lights... LIkely won't happen. Just so you know each 1141 lamp is about 1.5 amps Running.
Bobbo
Wherever I park
Posted: 05/19/20 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Before I tapped into that wire, I would pull its fuse and check to see just what doesn't work anymore. That way you have an idea of how much power that wire is currently supporting and just what will go out if you blow the fuse.
Bobbo and Lin
Lone Pine, CA
Posted: 11/12/20 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
The answers above are the basics electrical circuits and what you can and can’t do.
rockylarson
Jersey Shore
Posted: 11/13/20 06:26am Link  |  Quote  |  Print  |  Notify Moderator
I believe most auto store or big box store plugs and sockets are rated around 7amps, I chose to use Marinco rated at 15amps.
Marinco socket.
If you use their plugs they are waterproof and have a locking function.
I ran 10 gauge wire from my fuse panel and found an unassigned 20amp spot that I reduced to 10amp fuse. Heated CPAP and handheld car vacuum each have their own outlet.
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
