RV.Net Open Roads Forum: General RVing Issues: rubber roof sealants
 > rubber roof sealants
CodyClassB
None
Posted: 05/17/20 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
There are many kinds of rubber roof sealants. It appears that the on marketed for RV are more expensive. Which one do you use (most cost effective) . Thanks
https://www.amazon.com/s?k=Rubber+roof&ref=nb_sb_noss_2
way2roll
Wilmington NC
Posted: 05/17/20 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
I'm a fan of Dicor, but I would use whatever your manufacturer suggests.
Guy Roan
Posted: 05/17/20 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
If it is the top of the roof I wouldn't use anything except Dicor self
leveling.
Guy
gbopp
The Keystone State
Posted: 05/17/20 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
I'm assuming you're talking about roof coating and not caulking?
For caulking, Dicor self leveling is a good choice.
For coating, HENG'S Rubber Roof Coating is what I use. It goes on easily like paint, it's cost is lower and it needs no primer. It looks good and holds up well.
I put two coats on our 96 Southwind, 2 1/2 gallons for 30' of roof.
I'll use Heng's again.
Williams AZ area
Posted: 05/17/20 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
X2, gbopp. Heng’s is easy to use.
jdc1
Rescue, Ca
Posted: 05/17/20 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto.
But, if cost wasn't a factor, I'd take it to a truck bed liner guy. Rhino Liner and Line-X would last 50 years.
Scooter Alfa
Central Cal
Posted: 05/18/20 01:14am Link  |  Quote  |  Print  |  Notify Moderator
Go to Home Depot and get Henry's 887 silicon roofing. Look it up under Henry's roofing too. Its made for RV'S too.
Elk_traveler
maryland
Posted: 05/18/20 06:22am Link  |  Quote  |  Print  |  Notify Moderator
I have used the Dicor acrylic sealant on two different units over the last 10 years. It functions well and last for a time. I now own a 4 yr old Class C and just recently recoated the top (rubber roof) with the Henry's Tropicool 100% silicon. I can say it does a phenomenal job. It adheres extremely well to the surface and looks like a brand new roof. It is said to be much better than the acrylic material that Dicor sells which last in my case only 2-3yrs at best. I added two coats of the Tropicool silicon and it makes a tough and smooth finish to the rubber membrane. Don't think you can go wrong with this one. Not so expensive if purchased in the 5 gal size but also available in the 1 gal as well from Home Depot and many others. Check the Youtube site for RV coating.
