RV.Net Open Roads Forum: General RVing Issues: Chipmunks
 > Chipmunks
Page of 5
Guy Roan
Posted: 05/18/20 09:53am Link  |  Quote  |  Print  |  Notify Moderator
I usually miss with my 22, but now with my shot gun, I can't even find the body.
Guy
down home
south
Posted: 05/18/20 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
A Black Racer!
drsteve
Michigan
Posted: 05/18/20 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
Scent repellents do not work.
Figure out how they are gaining entry, and block the hole(s).
1991 Palomino Filly PUP
SAR Tracker
Central Oregon
Posted: 05/18/20 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
gbopp wrote:
SAR Tracker wrote:
peanut butter in a "hav-a-hart" trap, then drown 'em.
Isn't this an Oxymoron. [emoticon]
Maybe so, but it works. [emoticon]
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
winniman
muskoka Ontario
Posted: 05/18/20 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
If you happen to know anyone with a ferret, they will dispatch any squirrel or chippy in short order.
JimR 1
Custer South Dakota
Posted: 05/18/20 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
To answer your question if you are staying awhile like I did for the summer hosting in Oregon I did the following.
I made a cage around the MH by using 1 x 2 x 8 ft long furring strips and hardware cloth 1/2 inch. I made frames from the furring strips with the hardware cloth attached using staples with an Arrow stapler.
I measured along the bottom of the MH in 8 foot sections measuring the clearance from the ground to the MH on each end of the 8 foot section and then made the frame. I then inserted the frame in between the MH and ground. I made the frames a little taller so it was a tight fit.
For the wheels I used my wheel covers (MCD they cover the wheel well) as a template I cut the hardware cloth and used pipe insulation ( 3/4 inch) to go over the end of the hardware cloth so not to scratch the MH and made the fit tight and holding.
For other openings I just cut the hardware cloth to fit and attached using wire ties.
The front of the MH was a little harder to figure out because of the curve of the bumper but using just the hardware cloth with no framing worked very well from left to right on the bumper. Using 2 x 4s cut into 2 or 3 foot long sections and attached to the cloth on the bottom so that they could be used as a hold down using rocks on them. The top just fit behind the bumper.
Simple hand tools and a screw gun or drill will work but the one tool that I just happened to have was a pair of tin snips to cut the hardware cloth. WEAR GLOVES
Cost was a little over $100.00 the first year less the second year. Well worth the cost.
Time involve a couple of afternoons between duty rounds at the camp.
JimR
pfidahospud
Post Falls
Posted: 05/19/20 12:58am Link  |  Quote  |  Print  |  Notify Moderator
I’ve heard of making an appetizer of 1:1 peanut butter and plaster of paris, put in a spot that only the tree rats can find. As I understand it may induce terminal constipation.
schlep1967
Harrisburg, PA
Posted: 05/19/20 06:47am Link  |  Quote  |  Print  |  Notify Moderator
I'm pretty sure the trap and drown is a more humane answer. Either way they die, but with drowning it is quick as opposed to a week or more of suffering.
Also just an FYI, depending on the state you are in, they may be "protected". So don't advertise what you are doing either way.
Personally, a chipmunk is not much larger than a mouse. They are stronger. A quality mouse trap tied in place so it doesn't get drug off into an inaccessible area would be my approach.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Fisherman
Angus, Ontario, Canada
Posted: 05/19/20 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Well have to try that.
pcaffrey
Posted: 05/19/20 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Try the bucket "O" death. Five gallon bucket filled half way with water, cover water with a couple handful's of sunflower seeds. Give them a little ramp to go up, usually a trail of seeds. They dive in for the seeds not seeing the water and drown. This really works. I have caught many with this method.
Page of 5
 > Chipmunks
