RV.Net Open Roads Forum: Truck Campers: Looking into a Truck Camper
 > Looking into a Truck Camper
Page of 6
work2much
Jackson Ca
Posted: 05/18/20 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Also the Bigfoot 3000 model which is the only model I am aware of that had a slide was a conventional wood framed camper and susceptible to delamination just like any other std truck camper that isn't maintained properly. I have never seen a Bigfoot of Northern Lite clamshell fiberglass camper with a slide. I feel pretty certain that doesn't exist.
Bigfoot hinted about a slide a year or two ago in an interview but nothing tangible since.
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2018 Host Mammoth. 1080 Watts solar. 600 AH usable LFP battery. Magnum 2800 Watt inverter.
2020 Grand Design Solitude 2930RL 2400 watts solar. 600ah lithium. Magnum 4000 watt inverter.
Geo*Boy
Burlington
Posted: 05/18/20 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
geo11RT wrote:
JimK-NY wrote:
geo11RT wrote:
I find that hard to believe. 60 years of TCs with many makers and models and not one? I will wait for others to chime in.
I am not sure why that seems hard to believe. A truck camper must fit in the relatively small bed of a pickup truck. Trying to sleep or even fit 5 people in that space would require a beast of a truck camper with large slides.
If you re-read what I want, you will see that this is very feasible, it is not an absolute. Just making a blanket statement like the other Jim said is um, silly (to be nice). As you can see, there are numerous other people that have posted ideas and models and have made it work. And provided insight to other materials that would prevent delam. It boils down to if you can think outside the box or take things literally Jim.
Additionally, I know Northern did make a slide with their molded fiberglass shell.
You are incorrect about Northern Lite making a molded camper with a slide. Bigfoot made a slide out TC but it wasn’t molded fiberglass. It was a framed camper with filon siding.
geo11RT
Missouri
Posted: 05/18/20 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, that was already said twice now, including the post above yours. I never claimed to be an expert, that's what I am asking questions.
Freep
Wisconsin
Posted: 05/18/20 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
geo11RT wrote:
1- no laminate/gel coated sides. I do not want to deal with delam.
2- this means it has to be made of either molded fiberglass or aluminum
You should be more worried about what the frame is made of. A beautiful looking TC can have a tiny leak and rot the frame. But not if it's an aluminum frame.
2014 Lance 992
2014 Ram 3500 DRW Turbo diesel
geo11RT
Missouri
Posted: 05/18/20 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
My thinking was if there is no delam, that means no water/leaking. I suppose there could be a small one that goes unnoticed until too late. I will add this to my list as well.
Posted: 05/18/20 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
Depending on your budget and needs, honestly I wouldn't be too fixated on an aluminum frame being requisite. Bonus? Yes.
Was one of my "must haves" on our first camper. Got it, no issues.
Next and current camper (sold the first one in AK before we moved back down here for good $$) is the same model but a few years older and wood frame. That was 5 years ago and I have yet to notice a difference, but it was considerably cheaper than the first one.
specta
utah
Posted: 05/19/20 06:49am Link  |  Quote  |  Print  |  Notify Moderator
Kudos to those of you who pack an entire family into a truck camper.
I'm single and mines perfect for me.
However, I would consider making room for a cute younger redhead. [emoticon]
Kenny
2011 Chevy 2500 HD 6.0L 4wd
6580 lb truck 10540 fully loaded
Freep
Wisconsin
Posted: 05/19/20 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Yeah even with an aluminum frame I'm still paranoid about hidden rot in our TC. There are a lot of horror stories about having a beautiful TC only to have it fail spectacularly because of hidden rot. My next TC will have nothing that can rot, if I can find one.
Supercharged111
Colorado Springs, CO
Posted: 05/19/20 09:14am Link  |  Quote  |  Print  |  Notify Moderator
If Lance is on the table I'll plug my 1131 again. A queen over the cab, dinette bed, single bunk over the dinette, and a flip out tent in the back we have yet to use. The easier to find 1191 could be had with or without the tent with an otherwise identical floor plan. Single slide unit and 100% functional with the slide in. I use a Torklift superhitch and 48" extension to pull my enclosed car hauler behind it, so you'll have no tongue weight issues with your proposed setup, but I wonder about braking since the vehicle in tow can't help there if it's on all fours.
2007 Lance 1131
1997 GMC K3500 crew cab supercharged dually
mike/kellie
northern calif.
Posted: 05/19/20 09:24am Link  |  Quote  |  Print  |  Notify Moderator
I believe all tow vehicles exceeding a certain weigh are required to have a braking systems in place. These range from vacuum, surge or electric among others. In addition, there is usually a break away cable that engages the tow vehicle brakes if it should separate while being towed.
2015 Host Mammoth triple slide w/ TorkLift Fastguns
2015 Ram 5500 SLT cab & chassis with Douglass 9' utility body
Page of 6
