lagreca
San Diego
I was wondering if anyone has converted their twist lock shore power connection to something more robust?
I don't really like the current default setup where the shore power cable screws into the side of the trailer and sticks out.
I used to have a Class A motorhome that had a built in shore power cable, and it could just hang out a hatch hole on the bottom of the compartment.
Has anyone done a conversion like this? If you have, could you please share pictures?
fj12ryder
Platte City, MO
Have you looked at the 90° dog bones? I didn't care for the cord sticking straight out and putting a lot of stress on the plug, so I use one. It works a treat.
On Edit: Just noted you stated "more robust". Could you expand on that thought, I'm not sure what you're wanting.
edited 05/19/20 05:12pm by fj12ryder *
Howard and Peggy
"Don't Panic"
Likes to tow
Huntington WV
Get a 90 degree dog bone and you will love it!!
South of Lone Pine, California
X3 on the dog bone.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
valhalla360
No paticular place.
Twist lock is actually an upgrade but...
You can hard wire a cable in but if the trailer wasn't set up for that, you will have to dedicate a compartment to storage and then run cable from there to the breaker panel. Shouldn't be too hard assuming you can easily get to the back of the breaker panel to do the wiring.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Full Time spliting time between boat and 5er
Dave H M
IL
Wow, I converted from the old snake in the hole cord to the twist lock and love it. Haven't had an issue in 8 years on the straight out plug in. But would also look into a 90 dog bone if it bothered me.
Lynnmor
Red Lion
I got rid of the miserable and dangerous connection in the trailer wall and hardwired the cord.
RickLight
Washington
There's always these.
https://smartplug.com/rv/
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
pulpwood007
Hemphill, TX
I used PVC pipe and made a support stand that cradles the 50 amp cord right at the connector. It is adjustable for different heights based on campsites. Takes all strain off the screw on electrical connector. Cheap and easy to make.
Cummins12V98
on the road
This will do the job.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
