RV.Net Open Roads Forum: Fifth-Wheels: Retracting jacks while unhooked
 > Retracting jacks while unhooked
azdryheat
Tucson, AZ
Posted: 05/20/20 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure what you mean by zeroing out your Autolevel feature. If you just want to reprogram the level point of the trailer you don't need retract the jacks. Level the trailer and tell the system the new level per your owner's manual.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 05/20/20 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
My six point on the Bighorn lowers the front way down at the start of the auto level process. Never a problem. Chris
Ford Edge ST Twin Turbo 2.7L V6 335HP and 380 Lb Ft - Summer Home 2017 Bighorn 3575el. Can Am Spyder RT-L Chrome. Retired and enjoying it!
ACZL
UPstate,NY
Posted: 05/21/20 01:46am Link  |  Quote  |  Print  |  Notify Moderator
Our Big Country does the same as "Me Again's", sort of like it's going to church and kneeling down. Weird as all get all. Just don't put your truck under it and hit auto retract.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Super_Dave
Harrisville, UT
Posted: 05/23/20 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Pipes are or should be close to the tires. That area will never get close to the ground.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
justme
Posted: 05/23/20 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
Fnp5150 wrote:
This may be a dumb question, but here goes. I need to fully retract all my jacks on my Cougar so I can zero out the autolevel feature. In the past I've hooked up to the truck and then retracted. Just saw a video where someone retracted them while unhooked (was a different brand fiver), and it worked fine. I'm worried that my camper will go so low to the ground that it will damage my drain pipes for grey and black water. Is this possible, or do the manufacturers plan for this ahead of time and build them with enough room?
I don't know what you mean by "zero out the auto-level". If you mean calibrating for level then you simply follow the instructions in the manual which don't require full retraction.
Edd505
Elephant Butte, NM
Posted: 05/23/20 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly, I have done it several times. Read the manual and loose your man card, never.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
