RV.Net Open Roads Forum: Want to add solar battery charger for storage use
Search only in Toy Haulers
 > Want to add solar battery charger for storage use
Dan Diego
So Cal
Posted: 05/21/20 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
I want to add solar battery maintainer to my attitude toy hauler. I intend to hang solar panel in a trailer window, running cables to the battery. The panel would only be connected when in storage. I am currently using two GC2 6 volt batteries connected in series. I would be grateful for any advice or hardware recommendations.
Cheers!
Dan
2005 Ford F-250 Fx4 Longbed
2007 26' FSAK Eclipse Attitude Toyhauler
Mono Basin National Forest Scenic Area
Posted: 05/21/20 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
I use a 30 watt panel and $22 weatherproof controller from WindyNation. The panel is roof mounted, however, on top of my RV cover.
time2roll
Posted: 05/21/20 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.renogy.com/50-watt-12v-monocrystalline-starter-kit/
675w Solar pictures back up
2oldman
New Mexico
Posted: 05/21/20 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
What is the wattage of the panel? Generally you're better off to disconnect a battery cable and check monthly.
dedmiston
So Cal
Posted: 05/21/20 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Dan - Have you considered going full steam with your solar? We added 700W of panels to our roof a little over a year ago and it was one of the best upgrades we ever did. We hardly run our generator anymore.
If you plan to keep your hauler for a long time, it's a great investment and a HUGE convenience.
(4 x 6v batteries)
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Posted: 05/21/20 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
For those who check their batteries and can recharge in some way, yes, 2oldman. For the majority of RV owners you’d be lucky if they check anything at any time until it doesn’t work or blows out.
jdc1
Rescue, Ca
Posted: 05/21/20 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Yep...go big, as dedmiston says. 100-200watts will keep you happy when you're out there in Glamis or Borrego.
pianotuna
Regina, SK, Canada
Posted: 05/21/20 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
Putting the panel in a window may reduce the power output a LOT.
Far better to permanently mount on the roof.
For 2 golf cart batteries I'd recommend 140 watts (or more).
Regards, Don
Posted: 05/21/20 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
But I say “go appropriate” based on an energy survey of what you use (amp hours) or what you would like to use. Throwing money (solar watts) at a problem (need more power) isn’t the answer.
garym114
Bluff Dale, Texas
Posted: 05/22/20 12:11am Link  |  Quote  |  Print  |  Notify Moderator
Save your money, charge the batteries fully and disconnect the ground battery cable. Batteries will not lose their charge.
