RV.Net Open Roads Forum: Want to add solar battery charger for storage use
Search only in Toy Haulers
 > Want to add solar battery charger for storage use
RickLight
Washington
Posted: 05/22/20 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
Last winter I used a 5W panel for 300AH of lead acid. It also powered 2 ultrasonic rodent deterrents. We aren't a major winter sun zone.
You don't need to spend mega bucks!
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
Dan Diego
So Cal
Posted: 07/01/20 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for the advice. I am not yet committed to the full solar roof option. I was just looking for something to keep the batteries from running down in a period of inactivity.
I opted for a cheap fix. $30 7 watt solar panel from harbor freight. $33 Battery Tender solar regulator. $10 extension cable. When in storage, I put the 14x14 solar panel in the window with the most sun exposure and have it cabled directly to the battery. So far, so good. I will have better feedback when in storage for a period longer than a month.
Cheers!
Dan
2005 Ford F-250 Fx4 Longbed
2007 26' FSAK Eclipse Attitude Toyhauler
pianotuna
Regina, SK, Canada
Posted: 07/01/20 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Return them. Fully charge the battery bank. Disconnect the ground cable. Why waste your money?
Regards, Don
Dan Diego
So Cal
Posted: 07/01/20 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
I do not disagree with your post. My situation is that I do not have access to electrical at my storage yard. I also do not have the ability to keep my trailer in my driveway over night without running afoul of my HOA. The effort to pull my batteries, charge them for a day, then return them to the trailer is significant with recent shoulder problems. For me, this seemed worth the risk.
dedmiston
So Cal
Posted: 07/01/20 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
jdc1 wrote:
Yep...go big, as dedmiston says. 100-200watts will keep you happy when you're out there in Glamis or Borrego.
We put in 700 watts of panels. You can see the sun get dim when it comes over our roof. I think we even get a little charge from the full moon.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
nayther
Burbank, CA
Posted: 07/02/20 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
I would not go to all that trouble. batteries should be fully charged after camping by pulling it home. Once parked in storage with 90% plus SOC disconnect the positive lead and walk away, reconnect when you return. You'll have batteries in nearly the same SOC as when you parked it. BIL has a battery for his boat (standard lead acid group 24 Marine) that is 10+ years old. He disconnects when he parks it and all is good.
Why do you want to keep 12v connected in storage? Just curious
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
Dirtclods
Newport Beach
Posted: 07/05/20 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Just keep an eye on your battery levels.
Dan Diego
So Cal
Posted: 07/05/20 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have and use a battery disconnect switch on my trailer when in storage.
Due to health issues, I was unable to perform any maintenance on my trailer for seven months, last year. In that time, the batteries had run down significantly. That is why I felt compelled to take some action. The easiest thing for me to do was the small solar panel. I will see soon enough if it was a good decision or not.
I am encouraged that you get great life out of the battery by charging before storing and disconnecting cable. Thanks for your advice.
Rockinfigs
So Cal
Posted: 07/06/20 09:36am Link  |  Quote  |  Print  |  Notify Moderator
yeah i would go big also...I have two 12v lithium batteries connected to 420watt solars...love it especially the lithium batts.
2019 Ford f350 cclb 6.7 diesel black sports package
2020 eclipse attitude 3218mm
2014 rzr 4 800
nayther
Burbank, CA
Posted: 07/06/20 10:56am Link  |  Quote  |  Print  |  Notify Moderator
if there is significant drain with the disconnect open then you must have something connected "ahead" of the disconnect, perhaps the breakaway switch or tongue jack? Try disconnecting the ground wire AT the battery.
