RV.Net Open Roads Forum: Class A Motorhomes: Door hard to open from outside
 > Door hard to open from outside
Page of 5
CA Traveler
The Western States
Posted: 05/21/20 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
BTW On mine the striker bolts float vs hard tightened and need to be lubed.
2014 Grand Cherokee Overland
Bob
CA Traveler
The Western States
Posted: 05/21/20 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Do you see a crack on the botom outside of the latch?
fcooper
St. Augustine, Florida
Posted: 05/21/20 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
I had this same problem on a 2000 Holiday Rambler Endeavor DP. I don't know if your door is the same, but maybe this can help.
I don't remember exactly how I disassembled the structure, but I found an adjustable link in the lock assembly that controlled the movement of the latch when the outside door handle was utilized. After adjusting the link, the problem was eliminated.
Fred
Fred & Vicki
Monaramblee
Canada
Posted: 05/22/20 04:19am Link  |  Quote  |  Print  |  Notify Moderator
No i dont.
2008 Holiday rambler Vacationer XL
340 HP Cummins
Monaramblee
Canada
Posted: 05/22/20 04:20am Link  |  Quote  |  Print  |  Notify Moderator
I suspect you have the same door....i will take a pic of the bolts and try to post.
Monaramblee
Canada
Posted: 05/22/20 04:24am Link  |  Quote  |  Print  |  Notify Moderator
Fred
Thats encouraging. My concern is that we might eventually be locked out.
Monaramblee
Canada
Posted: 05/22/20 05:14am Link  |  Quote  |  Print  |  Notify Moderator
I have no clue how to upload a pic. I guess i will be opening another thread.
Wherever I happen to park
Posted: 05/22/20 06:02am Link  |  Quote  |  Print  |  Notify Moderator
jdc1 wrote:
Yea, They aren't made with the best of metals.
That... Is a MAJOR understatement
To the OP
If you hook your fingers on the right side of the handle.. Put your THUMB on the left just past the pivot. seems to work better. on mine.
Same with basement only it's bottom and top instead of right and left.
Home is where I park it.
Monaramblee
Canada
Posted: 05/22/20 06:21am Link  |  Quote  |  Print  |  Notify Moderator
To the OP
I will try that thanks.....made an observation this morning while the door is open. The inside handle easily opens both latches but the outside handle struggles to open only the bottom latch. Not sure how the door opens i guess it must be slightly unlocking the top latch. Anyways we are at a point now where my wife cant open the door at all and i have to use some strength. Was also wondering how the striker bolts can be removed?
* This post was edited 05/22/20 07:00am by Monaramblee *
Gjac
Milford, CT
Posted: 05/22/20 07:11am Link  |  Quote  |  Print  |  Notify Moderator
The Trimark door latch is problematic and can fail in a number of ways, the worst is when the latch it self just breaks, it is made from a cast zinc alloy which is not very strong. The cam is just plastic and can break also. I have replaced mine twice before I understood these two problems. You can adjust the door latch, lube the cam and latch itself, and press in on the outside door to remove some stress on the latch to make it easier to open before pulling on the handle. Eventually the latch itself will break. When mine broke for the second time I made a backing plate from steel to join the broken pieces together and so for after two years is working fine. The real solution is to have a machine shop make a one out of steel. Some one posted that Trimark now makes one with a steel latch at twice the price.
Page of 5
