RV.Net Open Roads Forum: Class A Motorhomes: Door hard to open from outside
 > Door hard to open from outside
Page of 5
Johno02
Lexington, TN USA
Posted: 05/23/20 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
duplicate, deleted. sorry.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and a grouchy, old, tiny dog
Monaramblee
Canada
Posted: 05/23/20 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Yes i have a window open and a stepladder handy. Thankyou
2008 Holiday rambler Vacationer XL
340 HP Cummins
skipsor
Thousand Oaks, CA
Posted: 05/23/20 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Why don't you take it to a locksmith and have them replace it? It would seem to be much easier than long distance Q&A and maybe destroying part of your door.
Monaramblee
Canada
Posted: 05/23/20 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
Im not sure what you mean about long distance q@a but taking it to a locksmith will be a considered option.
Thankyou
dougrainer
Carrolton, Texas
Posted: 05/24/20 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Easy answer. Locksmith's do not have RV door lock assemblies or their parts. They have key tumblers only. Doug
Monaramblee
Canada
Posted: 05/24/20 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
bjbear wrote:
Monaramblee wrote:
Holiday rambler monaco. The door opens easily from the inside but from the outside i have to pull hard on the handle. Ive lubricated everything, its not the door sticking as it opens easily from the inside.
Any ideas would be appreciated.
Take a look at: http://www.visualsc.com/monaco_door_adjust.pdf. It has a lot of info about the door handles on Monaco Family Coaches.
Usually, if the handle has to be pulled farther than normal, it is either the bushing or the rod adjustment. The bushing is the first place to look. If left as is, so that you have to pull real hard on the door handle to open, it will result in a broken handle and you will have to replace it. Will also leave you locked out of your coach. Happened to me!!!
That linc was quite informative
Thankyou....
Monaramblee
Canada
Posted: 05/24/20 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
Good to know
Thankyou
Monaramblee
Canada
Posted: 06/20/20 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
I removed the two screws from the little black plate on the inside handle but i cant get it off. Do i have to remove the 8 screws from the larger plate to remove the small black plate?
PastorCharlie
NC
Posted: 06/21/20 08:05am Link  |  Quote  |  Print  |  Notify Moderator
The exterior door handle may fail and prevent entry to the coach. In this case, when you pull the outside handle,
it will move very easily and the door will not unlatch.
This will lock you out of your coach. The inside handle will still function so if you
have an alternate access such as described later in the document, you will be able
to open the door.
To open the door from the outside, you can drill the door handle.
? Using a ¾” to 1” hole saw (1” shown), carefully drill a hole in the top
left hand side of the handle. Be careful not to cut into the inside latch.
The top of the hole should be level with the bottom of the lock.
? You can then use a large flat bladed screw driver to push down the
inside latch as shown by the yellow arrow.
Picture illustration available on website.
CA Traveler
The Western States
Posted: 06/21/20 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Nice writeup. My issue was the outside Trimark pot metal latch. It cracked at the bottom which is where all the stress is to open the door. I was able to use a screwdriver on the lower piece to open the door. When the new one also failed on the road I used JB Weld to get home and replace it. However once home applied another layer of JB Weld. Did the same on the old latch and carry it in the MH. Years later the first repaired latch is still in use.
2014 Grand Cherokee Overland
Bob
Page of 5
