RV.Net Open Roads Forum: Class A Motorhomes: Door hard to open from outside
 > Door hard to open from outside
Page of 5
Monaramblee
Canada
Posted: 06/21/20 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
If the inside handle easily opens both latches does that rule out adjustment? Isnt the long rod operated by both the inside and outside handles? The outside handle willopen both latches if i jerk the handle hard.....
2008 Holiday rambler Vacationer XL
340 HP Cummins
ARMDR
Kansas
Posted: 06/22/20 05:58am Link  |  Quote  |  Print  |  Notify Moderator
There is a kit on the market to fix the Trimark 060-1650 or T507 handle. I have had 3 of the handles break, 2 of them the pot metal striker, and one of the steel ones. The steel one didn't break the metal, but a plastic piece broke and jammed the handle. A friend told me about this kit, and I got 3 of them. They took 3 minutes to install, and there's no plastic to break. I found them on Ebay. After spending over $500, I was ready to try anything.
bjbear
Cold Lake, AB, Can
Posted: 06/22/20 09:00am Link  |  Quote  |  Print  |  Notify Moderator
You would think so, but the inside handle has a larger range of movement than the outside. That means that the door will stop working sooner with the outside handle while the inside will still function.
2006 Monaco Camelot 42-DSQ
09 Blazer 20' Covered Trailer
Toad - 2019 Wrangler JL Rubicon Unlimited
My Website
Monaramblee
Canada
Posted: 06/22/20 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for that info it makes sense. Now if i can get the inside handle cover off i will be in business.
JC2
Mo/Texas
Posted: 06/22/20 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Would you by chance have a link to the kit available from E-Bay?
2010 Newmar Dutch Aire 4304,Cummins ISL 425hp,Spartan MM Chassis,2013 Chev Equinox AWD Towed,Ready Brute Elite TowBar/Brake,FMCA #402879,SKP#120487
Penny07
Denver
Posted: 06/23/20 06:29am Link  |  Quote  |  Print  |  Notify Moderator
There are ***Link Removed***magnetic screen door which are easy to open.
Monaramblee
Canada
Posted: 06/28/20 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
So today the outside handle broke leaving a piece at the top and bottom.The top does nothing but the remaining small piece of handle at the bottom opens the door better then before the handle broke. So now i dont think it needs an adjustment i think the handle had issues.
Page of 5
