Riley01
Michigan
Hi All,
Is this mat sufficient for underneath a truck camper? I already bought it but want to be sure this is what I need. If it makes any difference I have the factory Ram sprayed bed liner.
Truck Mat
![[image]](https://www.imagecoast.com/images/Riley1/mat.jpg)
Thanks,
Rick
2019 Ram 3500 CC/8' bed/DRW/4WD/factory air leveling
CTD HO/Aisin/4:10/max tow package
Slymer
Ontario, Canada
Looks good, but IMHO 3/8" is a lot thicker than it needs to be. You don't really need it for cushioning, just for anti-slip. If too thick it can add to "top heavy" issues you may have. I see that as being the only possible downside.
Geo*Boy
Unknown
Nice mat.
specta
utah
I think its perfect.
My truck came with a Turbo-Liner bed liner so I saw no need to add anything else.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
6580 lb truck 10540 fully loaded
JimK-NY
NY
I have a sprayed in liner and use a mat. In addition I had to add wood slats under the camper to achieve the proper clearance.
I would guess my mat is about 3/8" thick. It is heavy and has lasted for 9 years with no signs of wearing out.
MORSNOW
Mountain Home, ID
Looks good to me too. I just use a basic rectangle shaped rubber mat, it still looks and works like new on its 8 summer season.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
sbryan@vtbryans.com
Vermont
I have the same mat in my F350. Works great and is a perfect fit. Much lighter than stall mats. My Igloo rides on it just fine. Good choice.
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
Kayteg1
California > Nevada
I have factory mat on my F350 and it works perfect.
It is heavy, but then I don't have to worry about wind picking it up. On previous truck I had like 3/8" thick rubber mat and I had to roll it each time I took camper off.
The TC I used had metal flashing with screws at the bottom, what would wear holes even in spray on liner.
Slymer wrote: Looks good, but IMHO 3/8" is a lot thicker than it needs to be. You don't really need it for cushioning, just for anti-slip. If too thick it can add to "top heavy" issues you may have. I see that as being the only possible downside.
Huh?
You’ve seen rubber bed mats that are considerably thinner??
$20 says you can’t tell the difference in 1/2” of center of gravity.
Riley01
Michigan
Thanks for all of the replies. I hope to put in a couple of offers for a new camper this week. I have the hardware for mounting it along with the fast guns. I finally got around to opening the boxes up and found I got 2 sets of rear hardware and no front.
Rick
