RV.Net Open Roads Forum: Class A Motorhomes: Big boy isolator and BIRD Isolator
 > Big boy isolator and BIRD Isolator
Leonandlisa
Las Vegas
Posted: 05/25/20 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
So I have a new to me coachmen’s sportscoach elite diesel pusher, replaced the coach batteries with battle born lithium, pulled out the big boy isolator and installed the LiFePO4 Battery Isolation Manager.
On the opposite side of coach I was replacing the inverter charger and I removed a protective cover and there was a Bird isolator device. Should a unit have both wired in, or now that I have lifepo4 manager installed should I remove the bird unit and pieces?
Thanks
dougrainer
Carrolton, Texas
Posted: 05/25/20 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
Per the instructions the current BIRD is not needed as the LiFePO4 Battery Isolation Manager does that function. Doug
pianotuna
Regina, SK, Canada
Posted: 05/25/20 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
If it is not connected leave it in place. You might find it useful at some future point in time--or the next owner might.
Regards, Don
Leonandlisa
Las Vegas
Posted: 05/25/20 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies, that is what I will do.
Leon
