RV.Net Open Roads Forum: Fifth-Wheels: Tire Balance
 > Tire Balance
Page of 7
RAS43
Littleton,CO
Posted: 05/29/20 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
Weights could be on the inside. That is where Big O put them on my chrome boat trailer wheels for a clean look.
Cummins12V98
on the road
Posted: 05/29/20 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
You want me to take a pic of the inside?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
pcm1959
home
Posted: 05/30/20 05:56am Link  |  Quote  |  Print  |  Notify Moderator
I'm not educated enough to advise but I did balance my new trailer tires. I have disc brakes so don't if that's different in terms of what's been discussed. One difference I can tell since installing my new balanced tires is I had a lower body panel screw that would always back out during travel. Just towed 350 miles and it didn't move.
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
RAS43
Littleton,CO
Posted: 05/30/20 06:19am Link  |  Quote  |  Print  |  Notify Moderator
NOPE!
memtb
Wyoming
Posted: 05/30/20 06:54am Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor, They are pretty popular in the trucking industry, and also many motorcyclist use them. I’m experimenting with them on a couple of trailers and on our Ram tow vehicle (19.5” tires/steel rims). So far so good,very smooth ride also.....though they don’t “soften the shock”, when those 14 ply tires hit a pothole! [emoticon] memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
fj12ryder
Platte City, MO
Posted: 05/30/20 07:51am Link  |  Quote  |  Print  |  Notify Moderator
"Some" motorcyclists use them, not "many". Definitely in the minority. They seem to do no harm at low speed, but I've heard of issues at higher speeds. I balance my wheels the old fashioned way. I figure since there's no way to check the balance of a tire with the beads, you're just taking their word that they work.
Caveat emptor.
Howard and Peggy
"Don't Panic"
RCMAN46
NorthWest
Posted: 05/30/20 07:57am Link  |  Quote  |  Print  |  Notify Moderator
If a tire is properly dynamic balanced there may be weights on both the inside and outside.
Often the weights on the inside will not be in the same location as the outside. That is how the dynamic balance is achieved.
Steakman
Calgary, Alberta
Posted: 05/30/20 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
Hmmm.. I balance my 16" tires. Seems to me to be simple common sense..NO.?
But it also seems to me that tires will rot before they wear out on most RV's...
Cheers...
M'self and the Bride...of 32 yrs
'06 GMC DMax CCSB 594,545 km (368,890 miles)
2003 Citation 26RKS.
Cummins12V98
on the road
Posted: 05/30/20 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
An out of balanced tire would effect the wheel bearings.
Huntindog
Phoenix AZ
Posted: 05/30/20 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor wrote:
memtb wrote:
If we’re concerned about the drum being out of balance....why not use “balance beads”? That should take care of that issue....unless it’s “very” badly out of balance! memtb
Not a believer in those, they need to reorient themselves every time the speed drops to a certain point. I asked the believers this question a long time ago: How many ounces of beads would you add to a tire that is 4 ounces out of balance with a brake drum that is 5.5 ounces out? Never got an answer. This is a real situation that I experienced. I knew the heavy spots on both and mounted with them opposed, so only 1.5 ounces of weight were required. For the bead fans, please calculate the amount needed (hint: it would be between 2 and 14 ounces).
I am not going to do the math, but the Drum needing 5.5 oz would be less it the weights were at the outer circumference of the tire... Same goes for the tire to a lesser extent... But the math really isn't that critical with the beads. Any extra beads will distribute themselves evenly aorund the tire.
The only downside I have witnessed with beads on one vehicle was a F450 that would shudder at low speeds when the beads were not distributed around the tire...(front tires) It happened briefly when speeding up, and slowing down.
The owner took the beads out and used normal balancing to fix it
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
Full Body Paint, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
1020 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
Page of 7
 > Tire Balance
