RV.Net Open Roads Forum: Getting no power at all chassis or coach Help please
 > Getting no power at all chassis or coach Help please
Movhs29
Home
Posted: 05/26/20 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
I got a 1997 golf stream scenic cruiser F53 chassis 460 engine and I started having some issues when I would go to start it you would hear a clicking noise in the engine bay I’m pretty sure it’s called a starter Solenoid I replace that and it did not fix the problem so I put the old one back on and then I come out the next day and everything in the RV is dead nothing will work No power or zero is the code or chassis when you walk in the door on your life you have the buttons to turn your chassis on or off in your coach on or off them buttons will not do anything when you push them you would normally hear a click now it’s nothing all my batteries are good I just don’t know what happen is there an in-line fuse please help
* This post was edited 05/26/20 08:52pm by Movhs29 *
garyemunson
Reno, Nevada
Posted: 05/27/20 04:37am Link  |  Quote  |  Print  |  Notify Moderator
Sure you got the wires back in the right place?
wanderingaimlessly
SOBOVA
Posted: 05/27/20 06:14am Link  |  Quote  |  Print  |  Notify Moderator
As mentioned above, verify you rewired correctly. Then,,,
Check your grounds. Both ends, where they meet the batteries and the frame.
rgatijnet1
Posted: 05/27/20 06:39am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like a cable failure on either the ground side or the hot side of your battery connections.
Lt46
Central Florida
Posted: 05/27/20 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Put a meter on your batteries, they're probably below 12v. The click you heard was probably the starter solenoid trying to work but did not have enough juice in the batteries to make it happen. Definitely recheck your connections at the solenoid.
Peter & Dawn
97 Winnebago Adventurer 37RW
F53/460 w/ tag axle
96 Prowler 27X SOLD
IAFF L-792 (Ret.)
jdc1
Rescue, Ca
Posted: 05/27/20 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Start removing and cleaning all the battery cables and connections. It happens to my F350 at least once a year. Use baking soda and water.
Racklefratz
Everywhere
Posted: 05/27/20 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Shouldn't. There is a spray-on product you apply to clean battery connections that prevents that kind of corrosion built-up. It works.
rgatijnet1
Posted: 05/27/20 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind that you can use a voltmeter to check for voltage and continuity but it will NOT tell you about the load carrying capacity of the main cables. In other words if you have a cable going from the battery to the starter that consists of 40 strands of wire and 39 of those strands are broken, your voltmeter will read the voltage as being OK even tho there is no way that the cable can carry the current necessary to turn over the starter with one strand of wire. A severely corroded cable will usually test fine with a voltmeter but it will not be able to handle the amps that your starter and charging circuits.
* This post was edited 05/27/20 06:04pm by rgatijnet1 *
