Brockc
SC
Hello. I need to seal my TT roof. I never used the Dicor cleaner in the past. Just Dawn detergent and water.
The "Dicor System" calls for the part 1 cleaner so the sealant will work correctly, etc..
Should I actually use this, or can I just give it a good cleaning with some detergent and water?
Thanks
DancinCampers
Louisiana
Use the cleaner IMHO
Dan & Sharon (Kasey, Our Yorkie, RIP 9Jan'05-26Jul'17)
2012 Winnebago Journey 36M
2006 Jeep Liberty, Blue Ox Aventa II, SMI Silent Partner
If You Obey All The Rules, You Miss All The Fun
cavie
Cleaner. Same when using Eternabond tape.
gbopp
The Keystone State
Use the cleaner. Do it once, do it right.
Brockc
SC
OK..good enough for me. I'll order the cleaner today. Thanks
Brockc
SC
Another question.... watching video on the Dicor cleaning/application system, it suggests wrapping the RV in plastic prior to applying the cleaner.
Is this really necessary?
This plastic wrapping is the reason I haven't done the Dicor system before.
Thanks
Super_Dave
Harrisville, UT
Can you be a little more specific in what you are actually sealing? Vents, seams, entire roof? I would have told you that denatured alcohol is what I clean my rubber roof with before sealing. As for outside edges near the siding, I use some green painters tape.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
Brockc
SC
I want to clean and apply a roll on sealant/coating to the entire roof.
aguablanco
Mesa, AZ
Brockc wrote: Hello. I need to seal my TT roof. I never used the Dicor cleaner in the past. Just Dawn detergent and water.
Thanks
I used this product last spring with great success. First, it is imperative to use the cleaner as it also acts as an activator for the sealer. Second, I wrapped the entire trailer with the very thin plastic sheeting as Dicor says the activator/cleaner can stain the sides of the unit. Don't forget to take off the AC shroud, reefer shroud and anything else you don't want the sealer on. After cleaning the roof I removed the plastic immediately. I went around all of the openings with a brush at least twice. Finally rolled the entire roof 3 times with the proper amount of time between coats. Also went around the edge of the roof where I couldn't roll with a brush 2 or 3 times. Took an entire day with almost no help after putting the plastic on. Roof looked great then and still does after ~16 months in the AZ sun. Don't try to cheat, do it once, do it right and move on to something else.
RichH
2017 Ram 1500 EcoDiesel
8 Speed Transmission
2010 Dutchmen 24 FB-SL
Curt 10,000# WDH
Never underestimate the power of stupid people in large groups.
Brockc
SC
Thanks for all the replies. I'll get the materials and plan for a day.
