RV.Net Open Roads Forum: Tow Vehicles: Service Trailer Brake System message
Search only in Tow Vehicles
 > Service Trailer Brake System message
plasticmaster
Home
Posted: 05/28/20 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
On my lunch break today, I drove my truck to the store, which is 5 minutes away. While driving the "service trailer brake system " message chimed and came up on the dash. It did this several times. I then drove 5 minutes back to work and it happened several more times. When I went home after work (about a 30 minute drive) it never happened. I was not towing anything. Truck is a 2014 Silverado with factory brake controller. It's never done this before today. Has anyone experienced this? Should I do anything before I tow my TT end of next week? Thanks.
Posted: 05/28/20 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
It’s not just GMs that have this glitch. But think I’ve seen it more in the ‘14 and ‘16 Chevys I’ve had than others.
It’s never been an issue when I hook up later.
Just test it with your camper first before you actually need the trailer brakes I spose.
SweetLou
La Quinta, CA USA
Posted: 05/29/20 06:03am Link  |  Quote  |  Print  |  Notify Moderator
Gremlins
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
Fisherman
Angus, Ontario, Canada
Posted: 05/29/20 06:46am Link  |  Quote  |  Print  |  Notify Moderator
The times up meter has run out on your trailer towing module, go to the dealer and give them more money. Probably corroded wiring shorting out somewhere.
Lynnmor
Red Lion
Posted: 05/29/20 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Start with cleaning and inspecting the trailer connector.
ktmrfs
Portland, Oregon
Posted: 05/29/20 09:48am Link  |  Quote  |  Print  |  Notify Moderator
yup. Make sure it is dry and no mud/dirt in it. What I've found is that after rainstorms or a good wash water can enter the connector and cause the service message. Once I blow it dry, message gone.
2011 Keystone Outback 295RE
PA12DRVR
Back in God's Country
Posted: 05/29/20 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Agree with all of the above, but FWIW, on my 2009 Silverado my experience was:
- Water gets into the connector for whatever reason and causes the service message
- After drying, it goes away.
- Service message is also triggered if the equipment gets dirt, debris etc along with the water
- However, after a while, the factory controller has just had enough and dies. It can be replaced / fixed but you may want to look into whether your controller can (even if repaired) adequately deal with whatever "modern" trailers you'll be pulling.
- I can't recall too many specifics, but my factory controller (from my 2009 model built in 2008) even when "repaired" wouldn't work with the electric over hydraulic brakes on my new 2018 boat trailer...it was roughly the same cost to get a new P3 installed as it was to get the fix done to the factory controller...so went with new. My 2009 is now my "work" truck and it still shows the "service trailer connector" message, but it's meaningless since the new controller is what's connected to the outlet.
CRL
My RV is a 1946 PA-12
Back in the GWN
RobWNY
Jamestown, NY
Posted: 05/29/20 11:57am Link  |  Quote  |  Print  |  Notify Moderator
FWIW, I've owned a 2012 Ford, a 2015 Chevy and I currently have a 2017 Ram. I never had any issues with the connector on the Ford or Ram but on the Chevy, I would get "trailer is no longer connected" at some point in my travels every time I towed my RV. I cleaned everything numerous times. Nothing made a difference. I never learned what the issue was but it sure was annoying.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Near Annett’s Mono Village, Bridgeport, CA
Posted: 05/29/20 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
RobWNY, cleaning my 2015 Tahoe did the trick for me. No issues yet on the 2019 Silverado.
Thermoguy
Graham, WA
Posted: 05/29/20 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
You should look at the Duramax forums. Lots of advice on that forum. It is probably not a dirty connector, maybe a corroded wire, or a steering stabilizer or a number of other things. I have only had that come on when connected to a trailer and Dielectric grease worked great.
