RV.Net Open Roads Forum: Tech Issues: Black Tank Valve Replacement
 > Black Tank Valve Replacement
Bill/Diana
Southeastern Pennsylvania
Posted: 05/29/20 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
It seems every 2 years I need to replace the valve on the black tank because it become very difficult to pull. What am I doing wrong that causes this to happen?
Bill & Diana
Please click here to visit our Website
2oldman
NM
Posted: 05/29/20 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure, so I direct you to a few youtube posts.
MDKMDK
Lockdown Gulag
Posted: 05/29/20 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
Try reducing fibre in diet, and increase Omega 3 fish/krill oil.
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
ernie1
Sacramento,California,USA
Posted: 05/29/20 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
I had a similar problem repeatedly until I found out that as I would change the seals or sometimes the entire valves, I would lube the seals and surfaces with vaseline or plumbers grease. This was recommended by the manufacturers and people on various sites. This was the problem: petroleum products will degrade rubber type products making them soft and spongy. In my case, the seals were swelling and would cause it to drag as the valves were being used. Now I only use silicone products like plumbers grease that is SILICONE based and not petroleum based. Have not had trouble for years since.
LadyRVer
Posted: 05/29/20 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
I spray the rod on pull handle with silicone spray every couple of months. Makes a big difference.
MDKMDK
Lockdown Gulag
How do you store the RV? Valves open or closed? After I dump and rinse the tanks before storage for any length of time, I close the valves and add a liberal dose of RV antifreeze, in the gray and black tanks, so that the valves and seals will be lubricated while the RV is sitting. It's the propylene glycol in the A/F that keeps the seals lubed. I've used it for over a decade with no problems. Valves will stick with lack of use, but once you pull/dump them a couple of times, they usually free up.
Bill/Diana
Posted: 05/30/20 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks folks for you input, ideas and suggestions. I'll use a combination of all that you have said.
RLS7201
Posted: 05/30/20 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
The seals in your waste tank valves are NOT RUBBER they are Buna-N. I install grease zerks on my valves years ago with NO SWELLING. I use the same grease that I lubricate my chassis with and the valves still work like new.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
MDKMDK
Lockdown Gulag
Posted: 05/30/20 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Buna-N is another name for nitrile rubber.
https://www.applerubber.com/hot-topics-f........ion-of-a-nitrile-buna-n-rubber-compound/
Rvpapa
Alberta , Can.
Posted: 05/30/20 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
One way that works for us that I do about once every couple of months.
Dump tank; dump a five gallon bucket of water through toilet, close dump valve and pour in about a pint of cheap vegetable cooking oil (canola) and then wait a few minutes to let the oil float on the surface of the water that remains. Next go out and work the valve open and closed as rapidly as you can. Valve gate will pick up enough oil after five or six open and closes to make a surprising difference. Works for us for a good twenty years so far.
Art.
