RV.Net Open Roads Forum: Tech Issues: Black Tank Valve Replacement
 > Black Tank Valve Replacement
Lynnmor
Red Lion
Posted: 05/31/20 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Not sure that vegetable oil is a good idea. I made cutting tools for a food processing plant and thought it would be a good idea to coat them with vegetable oil and stack them in a package. When the company went to use them, I got a phone call saying they couldn't pry them apart. The entire stack needed to be boiled.
A big issue with the drain valves is that the poor design has an opening into the rectangular portion where the is when open, and c**p goes in there. Just another cheap, poorly designed RV component.
fourthclassC
MA
Posted: 05/31/20 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Howdy, I thought I'd share my experience here. I had some leakage by the valve which made taking the cap off unpleasant. I changed the seals. seals only. This did not leak for about a year. Then it started leaking again. Just a little. So I think the blade itself is scored up from sand in the tank at some point. I think that if I change the entire valve (not just the seals) it will stop and last a long while without leakage/seepage.
Gjac
Milford, CT
Posted: 05/31/20 08:11am Link  |  Quote  |  Print  |  Notify Moderator
I had the same issue with my black tank valve. I added a grease fitting on top of both valves 10 years ago. I only greased the gray valve twice but grease the black valve 5 times in 10 years to keep them operating smoothly. The last thing you want to happen is to pull the T handle out of the plastic threads in the valve because it is so hard to open.
Bill/Diana
Southeastern Pennsylvania
Posted: 06/01/20 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
obviously this issue is more common than one might believe. Also, seems like lots of solutions tried by many of us. Again, thanks for all the comments.
Bill & Diana
Please click here to visit our Website
Harvey51
Alberta
Posted: 06/08/20 09:59am Link  |  Quote  |  Print  |  Notify Moderator
I had the annoying small leak that made removing the drain cap a messy job.
I followed advice from this forum to put a tablespoon of vegetable oil in the toilet and sink after every tank dump. No more leaks!
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
