RV.Net Open Roads Forum: Should we buy a Ford 5th Wheel Hitch?
Search only in Tow Vehicles
 > Should we buy a Ford 5th Wheel Hitch?
Crespro
SoCal
Posted: 05/30/20 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
We have an F250 on order and are thinking about a 5th wheel. It should be about 15.5K loaded (16.8K max gross weight). The Ford F250 has the eight foot box and the 5th wheel prep.
Would you buy the Ford hitch (18K rating) or another 5th wheel hitch?
Thanks,
Crespro
Crespro 2021 Grand Design 310GK-R, 2020 F250LB, 7.3L, 4.30, Reese 27K
Death Valley NP
Posted: 05/30/20 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
16,800 pounds with the F250 diesel?
Page 23 https://media.ford.com/content/dam/fordmedia/North%20America/US/product/2020/f-series-super-duty/2020-Ford_RVandTrailerTowingGuide.pdf
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
BB_TX
McKinney, Texas
Posted: 05/30/20 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
B&W is a very good and popular hitch. The Reese Elite and Pullrite hitches are very good. Curt also had it’s fans. And they all have ones to fit the Ford factory prep. Just whatever grabs you.
Be prepared for the discussion to change to, that is not enough truck for that 5er. It’s gonna happen.
rhagfo
Portland, OR
Posted: 05/30/20 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Crespro wrote:
Hello,
Thanks,
Crespro
Call your dealer and change your order to an F350 with a 12,400# GVWR. A 15k to 16k 5er will be over your weight rating for the F250. It sounds like CHP is starting to check weights on 5ers.
Crespro
SoCal
Posted: 05/30/20 11:03pm Link  |  Quote  |  Print  |  Notify Moderator
I appreciate the caution and have researched this quite a bit. It is rated for 19.2K on towing a 5th wheel, has 26K GCWR, 3.6K payload and scored 94.5 points on the IKE. It meets the weight specs. The Ford engineers are right on this truck.
MFL
Midwest
Posted: 05/31/20 03:59am Link  |  Quote  |  Print  |  Notify Moderator
Get the B&W for Ford OEM puck system. While other hitches will work, you will enjoy the ease of use, and solid build of the B&W. You will even save a few $$ by not getting the over priced Reese/Ford hitch.
Jerry
4x4ord
Alberta
Posted: 05/31/20 04:39am Link  |  Quote  |  Print  |  Notify Moderator
I would go with the B&W hitch. I really appreciate how easy it is to connect and disconnect with the B&W. It is a very well built and well designed hitch. Does your 5ver have an air ride pin box? If not you might want to consider the more expensive Hensley Trailer Saver or an AirSafe hitch.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
camp-n-family
London, Ontario
Posted: 05/31/20 07:00am Link  |  Quote  |  Print  |  Notify Moderator
Where did you get those numbers? Brochures? The only F250 that comes anywhere close is a stripped down 4x2 regular cab with a 6.2l. The actual numbers for a truck on the lot are usually much less once optioned out. You really should have ordered an F350. The price difference is usually less than $500.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
Death Valley NP
Posted: 05/31/20 07:40am Link  |  Quote  |  Print  |  Notify Moderator
“Where did you get those numbers? Brochures?”
Camp is right. OP didn’t get them from the 2020 Ford RV and Trailer Towing Guide. Wishful thinking.
ACZL
UPstate,NY
Crespro wrote:
Hello,
Thanks,
Crespro
On a 250? Ouch!!
B&W.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
