RV.Net Open Roads Forum: Should we buy a Ford 5th Wheel Hitch?
Search only in Tow Vehicles
 > Should we buy a Ford 5th Wheel Hitch?
cummins2014
Utah
Posted: 05/31/20 08:23am Link  |  Quote  |  Print  |  Notify Moderator
BB_TX wrote:
B&W is a very good and popular hitch. The Reese Elite and Pullrite hitches are very good. Curt also had it’s fans. And they all have ones to fit the Ford factory prep. Just whatever grabs you.
Be prepared for the discussion to change to, that is not enough truck for that 5er. It’s gonna happen.
If not mistaken that Ford hitch is a Reese Elite, and I have the slider version. Great hitch ,but heavy, and I prefer the Andersen. But as far the Reese Elite, its got as good a jaw system, and easy to hitch, and unhitch as any.
Cummins12V98
on the road
Posted: 05/31/20 08:41am Link  |  Quote  |  Print  |  Notify Moderator
The Ford hitch is actually a REESE hitch. You may want to see where it's made.
B&W is 100% Made In USA.
I agree on the 350!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Second Chance
Wherever...
Posted: 05/31/20 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
16,800 pounds with the F250 diesel?
Page 23 https://media.ford.com/content/dam/fordmedia/North%20America/US/product/2020/f-series-super-duty/2020-Ford_RVandTrailerTowingGuide.pdf
Made your link clickable:
Clicky
I agree - reconsider the combination.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
rhagfo
Portland, OR
Posted: 05/31/20 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Clicky
Rob
Fixed your fix![emoticon]
Fixed link
Rich1961
Colfax Calif.
Posted: 05/31/20 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Crespro wrote:
Hello,
We have an F250 on order and are thinking about a 5th wheel. It should be about 15.5K loaded (16.8K max gross weight). The Ford F250 has the eight foot box and the 5th wheel prep.
Would you buy the Ford hitch (18K rating) or another 5th wheel hitch?
Thanks,
Crespro
Crespro,
Are you aware of the drivers license requirement for 5th Wheels over 15k GVWR in California? Just asking as most aren't aware, and most dealers don't or won't tell you.
Rich
2016 Chevrolet/Duramax 3500HD Dually Crew Cab B&W RVK 3700 5th Wheel Hitch
2014 Arctic Fox 29-5T
Posted: 05/31/20 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Nope, it's a gasser and a 2 wheeler, so it has more "payload." Lol
Actually payload isn't the reason to upgrade and nothing wrong with a 250, but that truck will be suckin wind westbound anywhere where the wind blows.
Diesel ftw with a trailer that size or get used to the right lane and 4ways in headwinds and up mountians.
Beverley&Ken
Tottenham,Ontario
Posted: 05/31/20 11:50am Link  |  Quote  |  Print  |  Notify Moderator
Pin weight 16800 @ 20% is 3360 lbs leaving 240 lbs for all other cargo, including the hitch (200 +/- lbs) and passengers in the truck.
Pin weight maybe less but could be up to 25%. Also is that 3600 payload a brochure weight for a basic truck with no options.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
valhalla360
No paticular place.
Posted: 05/31/20 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Crespro wrote:
I appreciate the caution and have researched this quite a bit. It is rated for 19.2K on towing a 5th wheel, has 26K GCWR, 3.6K payload and scored 94.5 points on the IKE. It meets the weight specs. The Ford engineers are right on this truck.
At 16.8k loaded, assuming 20% hitch weight (lower end of recommended percentages), that's 3360lb hitch weight. Add in a 200lb hitch and you used your full 3600lb payload before putting anything else in the truck.
People, firewood, gas jugs, running boards, etc...all count against your payload.
If it's nearer to the upper end of 25% you will be way over with an empty truck.
Not saying it will be a death trap but if you can change the order, why not fix the issue now when it's simple and cheap.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
rhagfo
Portland, OR
Posted: 05/31/20 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
X2!
Depending on tires and empty (unloaded ready to camp) scaled rear axle weigh you might need better tires.
Keep in mind that 3.6K payload is for a base model XL, so if it has any option packages , like the 5er perp, that number starts going down.
I think you will be first surprised at the payload on the yellow sticker, and the greater reduction once you scale ready to tow..
Crespro
SoCal
Posted: 05/31/20 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
Hello Folks,
I appreciate the thoughts of those who suggest we should all follow the proper specs and the statement that the Ford is a Reese hitch. Let me share our specs and then I will return to the 5th wheel hitch question.
We had a 40DP from 2005 until 2017, so some of our user specs come from that experience. We traveled with the 40 DP in all 48 lower states, but now plan to stay mostly on the California coast in our favorite RV parks. So a towable makes sense.
The Solitude we looked at Saturday passes the Kitchen, Living Room, Bath and One-Half, Bedroom, and Décor Specs.
The tow vehicle must pass both the Ford and the user specs. The current Super Duty Towing Guide on the Ford website shows 19,000# 5th wheel towing capacity for the 7.3 with 4.30 axle. The F250 truck manual shows 26,000# for the GCWR. The UVW spec is 6,500# for the 7.3, eight foot bed and our options. The gross is 10,000#, producing a payload of 3,500#. The RAWR is 6,340# and initial pin weight is 2,800#. With growth to 3,100# pin weight, DW and I, we should be about 15.5K on the 19K, 22K on the 26K and about 6K on the 6.34K axle ratings. We can store any extras in the RV.
The 40DP had four air bags for suspension and that has created an expectation. We hope the 4x2 front axle IFS and two airbags on the rear axle will produce a compliant ride spec. A 4WD or F350 will fail the desired ride spec. :-(
Many years ago I was in Detroit and had friends who were Ford engineers. The Ford engineers create the 19K and 26K specification with unpublished but real safety margins. My numbers show added safety margins over theirs (about 3K or 4K under the towing and GCVR numbers). I understand safety and these two margins are sufficient.
Thanks for everyone who responded. The Ford website does not offer any details other than the 18K rating on the Reese hitch. Knowing Ford, I suspect this is derated from a higher level.
Thanks for replying,
Crespro
Crespro 2021 Grand Design 310GK-R, 2020 F250LB, 7.3L, 4.30, Reese 27K
