RV.Net Open Roads Forum: General RVing Issues: Battery question
 > Battery question
mdcamping
CT
Posted: 05/31/20 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Just De-winterized the trailer yesterday, hooked up the battery that I keep in the house basement from winter storage. Noticed lights in TT didn't work. So far I have the trailer plugged in charging for almost a day. Put the trailer back on batter power only, noticed lights still not at full power.
Disconnected battery again, have 12.5 VDC at battery and 13.75 VDC on wire leads from trailer. So it seems the trailer is trying to charge the battery. I think the battery is 4 yrs old, how much more time should I wait before I spend $$$ on new one
Thanks for your replies
Mike
* This post was edited 05/31/20 06:31pm by mdcamping *
07 Toyota Tacoma,Double Cab, Max Towing 6,500lbs GCWR 11,100lbs
2011 Jayco X20E, Pro Series 800lb Weight Distributing Hitch
Husky Sway Bar, Prodigy Electronic Brake Control
McKesh Mirrors. "Towing with 210K"
Where we have camped
Lynnmor
Red Lion
Posted: 05/31/20 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
You should have kept the battery fully charged all winter, now it may be spent. Charge it some more and then take it to a place like the chain auto parts stores to have it tested.
Bishop area, California
Posted: 05/31/20 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
IMO your battery is toast. Keeping it charged is the key...not storing in the basement. A fully charged battery won’t freeze or we’d all be dead.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
MitchF150
Puyallup, WA
Posted: 05/31/20 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure you really clean the battery cables and posts... They may look clean.. But, give them a good wire brush clean and try again.
Good luck! Mitch
midnightsadie
ohio
Posted: 05/31/20 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
couple more things you need to do, all great advice above. buy a battery tender ,for when tt when just sitting . theres always a little battery use when the tt is just sitting in the drive. and always check the water every three months.
mdcamping
CT
Posted: 05/31/20 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
I do clean the posts, but now that I think of it the positive lead wire was rusted, I will cut back the wire. Battery had plenty of water.
Thanks everyone
Mike
Varmintmist
West PA
Posted: 06/05/20 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
Also you can try a real charger. Something like a garage will use. Sometimes you need to rock the batteries world.
Always cross your chains and grease your balls
07 F250
2019 Surveyor 27'
Harvey51
Alberta
Posted: 06/07/20 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
I think 13.75 volts is too low to revive an unhappy battery.
I have a Black & Decker smart charger that automatically goes up to 16 volts when needed. It also has a desulphate mode. It works very well!
I used to keep the batteries in the house but they got too heavy. I live in northern Alberta. Now I leave them in the motorhome and disconnect the batteries when not using them for more than a day unless the solar panel is keeping them fully charged. They stay over 12.6 V for at least a month. I’ve had poor results with trickle chargers.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
Posted: 06/07/20 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
Something is strange. Baytery might be toast but your converter and the battery at 12.5v should fully power the lights. Fix the bad terminal first.
Also unhook the battery and see if it maintains voltage for a day or so.
Have battery tested.
And you can try charging it again with something that puts higher voltage to it if your converter is only charging at 13.7.
Wherever I happen to park
Posted: 06/08/20 05:14am Link  |  Quote  |  Print  |  Notify Moderator
Test the batteries.. I have my own tester but you can get 'em tested at ye old auto store.
Make sure you did not flip the disconnect switch to OFF.
Home is where I park it.
 > Battery question
