RV.Net Open Roads Forum: Travel Trailers: New on tandem axle trailer.
 > New on tandem axle trailer.
Yosemite Sam1
Under the pines.
Posted: 05/31/20 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Is it normal that when doing a right backing maneuver the right. rear wheel of the trailer goes askew -- toe in, it appears?
Trailer is new and I recently checked the torque of the lug nuts are in order.
I'll appreciate any info.
Old-Biscuit
Verde Valley
Posted: 05/31/20 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
yes.....tight manuvering will cause one or other tire to 'slide' which can torque the suspension.
Normal.
When you pull forward wheels will straighten out
Yosemite Sam1
Under the pines.
Posted: 05/31/20 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Normal.
Thanks, that's very reassuring.
I appreciate it.
TomG2
Central Illinois
Posted: 05/31/20 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Like anything, there are specifications and limits for suspension twisting and turning. Bolts could be loose. Bushings may be missing. Just two possible problem areas. I would do some measuring and talk to the service department of your new trailer rather that ignore it because someone on the Internet said it was okay. I have seen that on our tandem axle dump trucks when the suspension was shot.
ORbiker
Springfield, Oregon
Posted: 05/31/20 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
Yep. The rubber leans over pretty good sometimes. Sometimes I will back off doing the tight back in and eaze forward for a fot or 2 and then continue with the back-up.
Even going forward on a tight turn, they will be a skidding of rear tires.
The triple axle reacts slow and tracks a bit inside on a turn. Swing WIDE.
KEN
I (2-10-05) bought a 2002 F350 CC SWD PSD and a new 2003 Citation 10'8. I have been a tent camper all my life. I wanted more comfort while camping and CraterLake Ski Patrol.
It's time for more space. I purchased a 2016 Grand Design 380TH as of 10-29-2015.
MitchF150
Puyallup, WA
Posted: 05/31/20 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
Also, if you are having to park your rig after turning hard like that, don't leave the wheels all torqued over.. What I do is I back up a foot or so more, then pull forward until they straighten out again. (or pull forward a bit and reverse if that's how you were turning) That will 'un-torque' the wheels to park it.
Mitch
* This post was edited 05/31/20 10:47pm by MitchF150 *
Ride S40T
OK
Posted: 05/31/20 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
Congrats on the new RV. Cheers to many miles of smiles.
And for goodness sake, try to avoid any curbs or rough surfaces on those sharp turns. Hard on the suspension.
2021 Grand Design 268BH
2019 GMC Sierra Denali HD 3500 SRW
Traveling K9s Diesel and Roger
guidry
Texas Cajun
Posted: 06/01/20 03:58am Link  |  Quote  |  Print  |  Notify Moderator
That’s also the reason for ST (trailer) tires versus LT (truck) tires.
JIMNLIN
Oklahoma
Posted: 06/01/20 06:20am Link  |  Quote  |  Print  |  Notify Moderator
LOL...thats a good one [emoticon]
jdc1
Rescue, Ca
Posted: 06/01/20 08:05am Link  |  Quote  |  Print  |  Notify Moderator
He's correct. The sidewalls on trailer tires are built to take the stress.
