RV.Net Open Roads Forum: Tow Vehicles: In bed diesel tanks
Search only in Tow Vehicles
 > In bed diesel tanks
Page of 8
Huntindog
Phoenix AZ
Posted: 06/03/20 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
I am looking at these for the new truck.
Probably in the 40-60 gallon range. Maybe with a tool box.
Those of you that have/had them, what are your likes and dislikes? What about brands? Good, better, best,,,, and why?
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
Full Body Paint, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
1380 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
fj12ryder
Platte City, MO
Posted: 06/03/20 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 35 gallon tank in the bed of my Dodge dually and simply love it. Best money I've ever spent on something that wasn't motorcycle related.
I love that I don't have to check out the fuel stations ahead of time to make sure I can get in, and, more importantly out, with that 40' toyhauler in tow. I can carry enough fuel to only have to fill up at the end of the day when the 5th wheel is not hooked up. Lowers the daily stress level considerably, especially if you're traveling the two lane highways with fewer big ol' truck stops.
I like taking breaks at rest stops, or parks rather than using the fuel stop as break time.
I like being on my schedule rather than the trucks fuel tank's schedule.
Okay, the cons...uh...well...hmm...it does cost more when I fill both tanks.
Howard and Peggy
"Don't Panic"
Lantley
Ellicott City, Maryland
Posted: 06/03/20 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
I have a simple 25 gallon Enduraplas tank. They make a 55 gallon tank also.
It is a simple transfer tank with a nozzle that you manually fill your tank with. I use a 12 volt jump box to power the built in pump.
It does the trick no installation required. I can move to my next truck or put it in another truck in minutes.
Not quite as convenient as a piped in tank but just as useful. Easily removable if you want the space back.
Works great. Use it when you want . Remove it if you want.
Very versatile and flexible
Enduraplas Tank
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Mbiviano
Denver
Posted: 06/03/20 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
60 ga. RDS gravity fed. Get fuel when it’s cheap and roll on.
Matt
2015 Forest River Wildcat 337FB Bunkhouse
2015 Ford F350 CC SRW PSD LB
Me/Wife/Twins/Dog
deltabravo
Spokane, WA
Posted: 06/03/20 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
Dislikes:
They take up bed space
Almost always have to drill through the bed to mount them
Almost always have to drill through the bed to wire them
The nozzle and pump assembly get messy and stinky.
I prefer OEM tank replacements from Titan Truck or other manufacturers.
Durb
NW
Posted: 06/03/20 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 41 gallon tank from Aluminum Tank Industries. I'm pleased with the quality and the price was good. It is gravity feed but I also installed an electric valve and indicator light. The gravity feed filler neck valve works fine; I just didn't trust it completely from the outset.
I reset my trip meter and use the MPG readout to calculate my fuel usage per fill up. I would prefer to have an in-cab gauge for the auxiliary, but I went on the cheap.
I agree with what FJ12 posted. Less stress and peace of mind. I also buy less expensive fuel; I calculate tank payback to be about three years.
I average 11.2 MPG towing which easily gives me 750 miles of range; more than I can do in a day. Most round trips I take, I can do on a single fill up, then hit Costco when I get home.
* This post was edited 06/03/20 09:35pm by Durb *
Nv Guy
Reno NV
Posted: 06/03/20 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Pretty much what FJ12 said. Travel with no fuel worries, drop the fiver at the CG, go find a good deal on fuel. I went with the pump - nozzle route as I didn't want to risk any warranty issues with the truck by cutting any hoses.
I went with the RDS 40 GA because of capacity. I didn't want 100 gallons or just 20. It also had to fit under my bed cover.
* This post was edited 06/03/20 09:54pm by Nv Guy *
Posted: 06/03/20 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
Have carried many slip tanks for many years.
RDS and JME are some of the nicest aluminum tanks IMO.
2017 Heartland Torque T29
Huntindog
Phoenix AZ
Posted: 06/04/20 01:52am Link  |  Quote  |  Print  |  Notify Moderator
deltabravo wrote:
Dislikes:
sounds like you are describing a transfer tank... That is not what I am considering.
Yes, I like the idea of a Titan etc, but there just isn't enough room under the truck for the capacity I am looking for.
valhalla360
No paticular place.
Posted: 06/04/20 04:29am Link  |  Quote  |  Print  |  Notify Moderator
Don't forget to account for it when considering payload. a 50gal metal tank is going to eat up around 500lb of payload when full.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Page of 8
